Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 173 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
820
785
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
SiliconFly
1,924
1,284
I agree with your point but it looks reasonable under load too. No it isn't able to compete with Apple but it at least dramatically improves on mobile RPL. I think MTL is alright but I wanted to see better PPW given the new node. The new iGPU is a very welcome improvement but I'm not too impressed with the performance of the CPU cores. Intel needs to replace RWC with something much better.
Like one reviewer said, Intel has a long way to go, but at lease MTL is the first step in the right direction!
The first real efficiency gain the CPU tile (P & E cores) will get is with ARL on 20A. We can expect a massive 35% to 40% PPW gain over MTL's CPU tile next year. RWC is technically a evolutionary dead end. Or simply vestigial remains from a bygone era. I think Intel chose to play it safe with MTL's CPU tile due to too many changes going into it's brand new architecture. ARL should fix it.
Reactions: controlflow
Hitman928
6,693
12,355
So basically in the heavy loading "test" the 7840U laptop consume 50W, wich is quite a lot for a U APU wich is suposed to go up to 30W, and the MTL laptop 35W, if that s not made up numbers dunno what it is...
And of course no idea of the quantity of work processed...
How do you get 50W for the APU from that chart?
SpudLobby
1,041
702
Lmao, Zenbook S14 with Ultra 7 and Phoenix-competitive battery life available at Bestbuy in the US for shipping or pickup by end of the month (23rd). We don’t even have an AMD equivalent yet in the US, and Phoenix has been out for 2-3 quarters.
Abwx
11,868
4,846
I said the laptop, not the APU.
But while we re at it this mean that the 7840U APU is running at about 35W TDP
while MTL is at barely 25W, that s how they get thoses fake battery life numbers.
Geddagod
1,513
1,613
Seeing these MTL results, I think a hypothetical 128 core GNR on Intel 4, like originally planned, would have had around the same perf of a 96 core Milan. 33% more cores, sure, but I think a Zen 4 core might actually end up having 20-30% higher perf/watt than RWC as well, at server power levels, meaning it will be clocking much better.
I am looking forward to individual RWC testing.
Also, even if RWC on Intel 3 is able to utilize all of their claimed perf/watt gains, at best it would be about matching a Zen 4 core in perf/watt. Meaning any perf/watt gains Zen 5 has over Zen 4, will be used to just crush GNR even further.
To match Zen 5, Intel may need 20A/ TSMC N3... while Zen 5 continues to use N4.
Even then, I still think GNR will be the most competitive server processor Intel has released in a while. But that says more about Intel's current standing than it does about GNR. I still think Turin won't be more than >50% faster than Granite Rapids on average, iso power (right now Genoa can outperform SPR by >75% in tasks like CB, while probably consuming less power lol).
Markfw
May 16, 2002
27,177
16,066
I did not even comment on it, and you are all over my case.
Chill dude.
So, now I will comment, sort of. Since whenever I am away from home with a laptop, it will always be on a browser with gmail open (I am deaf, so no cell phone), if I replace my 6850H laptop, it will not be an Intel.
TESKATLIPOKA
2,696
3,260
Yet I bought one today in Europe. Maybe you should ask why you can't buy one in USA, but can in other countries.
Hitman928
6,693
12,355
I calculate 38W for the whole laptop. . . probably means around 25W for the APU. Could easily be that depending on the power setting.
mikk
4,293
2,382
Under full load they could improve a lot, unfortunately the Soc will be almost the same, all or most Soc flaws from MTL will carry on to ARL. Same LP E core and IMC outside the compute tile for increased latency. The uncore power draw seems on the higher side even if it is improved. They will fix this for Lunar Lake but not for Arrow Lake. Lunar Lake doesn't even need LP E "workaround" cores.
Abwx
11,868
4,846
I thought that they had the same battery but MTL has a 75Wh one and the 7840U a 54Wh one, just imagine that it produce the same result as using different powers when it comes to battery life, so the logic still hold, and even more strongly...
H433x0n
1,224
1,606
Have you looked at the Emerald Rapids data? It's improved by a full +20% perf/watt at full load with even larger gains under partial load. On a per core basis, it's within striking distance with the top SKU trading blows with Epyc 9554 depending on workload. It's got me conflicted on what to expect with GNR.
jpiniero
16,720
7,181
Seems the main problem with Meteor is the loose binning cuz Intel 4. If the CPU tile was at TSMC, it would be much better.
SiliconFly
1,924
1,284
Afaik, the sooner they ditch RWC the better.
Reactions: Tlh97 and Exist50
Geddagod
1,513
1,613
One should expect ~20% from the arch (or more if the arch is as hyped up as it's supposed to be), and ~25% from the node. I expect the theoretical maximum to be ~50%. However, I don't think Intel is going to get anywhere near that- based on how disappointing RWC is.
Something interesting is that is if one is to draw parallels with ICL and RWC, one might expect really good gains from RWC on Intel 3, kinda like TGL on Intel 10 ESF. I mean, we will see tho.
The problem is how much power it consumes.
You read Raichu's twitter post as well? Lol
Hulk
3,719
True. But the real world scenario is somewhere in between. Actually, people tend to idle a lot.
I guess in a typical 8 hour work day, the systems tend to idle a lot more than we can imagine. Especially considering workloads like browsers & office/productivity apps in which their main and worker threads usually tend to spend most of the time in idle states.
This is in line with Intel's old "race to sleep" doctrine.
H433x0n
1,224
1,606
There's only one way to fix the loose binning...
You've got to eventually launch the process into production. The initial launch of A17 on N3B had loose binning too, it’s something that you really can’t fix until you’ve got the volume. In that sense having the tile on Intel 4 was a great pipe cleaner for Intel 3. I’m cautiously optimistic that the foundry has turned things around.
Reactions: SiliconFly
trivik12
348
318
Asus seem to be available to buy at best buy
$1300 for 32GB/1TB with 120 hz OLED display for a just released model is not bad.
MSI Prestige is available to order at Costco.
32GB/2TB/QHD+ IPS display.
Amazon has listed couple of Acer and MSI listed. But nothing seem to be ready for shipping. But Acer seem to be the lowest priced one at $999 for 16GB/1TB/QHD+ OLED display at 90hz.
SiliconFly
1,924
1,284
A core ultra 7 with 32gb ram, 1 tb ssd & qhd at around 900 to 1000 usd is reasonable. 1300 is overpriced imho.
Abwx
11,868
4,846
So, light use, which is where Meteor Lake shines. Of course you wouldn't want that. ;)
Well, in their WLAN surfing test NBC got 479 minutes with a 65Wh battery, a comparable 14" laptop with a 7840U and a 68Wh battery last 510mn, so dunno if its as efficient in regular light usage than some would think, but for sure that Intel marketing was very efficient to spin the numbers...
Reactions: Mopetar
SiliconFly
1,924
1,284
... the most recent iteration of Intel 7 being much better than it's given credit for...
RPL's Intel 7 (ESF+) UHP cells were one of the best for high performance and high frequencies. Draws too much power and generates too much heat. But performance wise, it rocked. Which is actually excellent for gaming, especially when coupled with a good dGPU. I have a RPL HX gaming laptop with RTX dGPU and it's an absolute gaming monster. Battery life is abysmal though and it comes with a pretty massive power brick. And the laptop runs pretty hot while gaming (both cpu & gpu). But it's still the best in class (high fps).
But as of today, Intel 7 has had its day. I believe even Intel 4 is a bit outdated by today's standards. Hoping 20A delivers!
