Page 171 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
869
805
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
adroc_thurston
7,387
10,137
Do they not know that SPEC2017 is especially demanding on the memory subsystem performance?
Well, no.
Outside of a few subtests, it is not.
Real membw stuff is things like HPCG that shred your cachemet into bits in the name of scaling something analogues to university student Python math code.
Abwx
11,891
4,875
Are the pro-AMDers blind? Do they need magnifying glasses to read the footnotes to find out the Intel ran SPECint_2017_base 1copy for 1T and ncopy for MT? Do they not know that SPEC2017 is especially demanding on the memory subsystem performance? And do they not see that the comparisons are with 7467 MT/s memory vs 6400 MT/s memory?
They say that they recompiled SPEC with ICC.
If RPL was that fast in ST Integer, 21% faster than AMD according to Intel, lol, it wouldnt lag by 10% IPC in 7 Zip ST or be trounced in Handbrake.
Abwx
11,891
4,875
How desperate one can be, to the point of releasing fake numbers, now even the 1370P at 30W has better perf/Watt than the 7840U@30W, even Apple is lagging compared to Intel.
They display the 165H has getting 2x more perf for 2x the TDP from 10W to 20W, laws of physics be damned, nothing is impossible for Intel s snake oil refiniries :
CouncilorIrissa
741
2,711
Intel's mature high clocking nodes really have a tendency to screw them over, don't they? It's what, third time when their new lineups lose in ST compared to predecessors (Haswell -> Broadwell, RPL -> MTL, Whiskey Lake -> Ice Lake)?
Reactions: Tlh97 and Exist50
Hitman928
6,720
12,426
So is your argument that Intel isn't being deceptive, just that they are purposefully crippling the competition to show that they have higher performance?
Hitman928
6,720
12,426
Looking good for casual use.
Yes, if you just let it sit idle or use your laptop as a really expensive e-book reader (which is basically what this test is), then battery life is phenomenal with MTL but I don't think this is very representative of even casual use. This is the situation I predicted MTL would look really good in, but that anything where you actually use your laptop as a laptop, I was very skeptical there would be much improvement. We still need to see more thorough battery tests but from what we have, the battery life doesn't look very much improved over RPL in typical use case scenarios.
cebri1
373
405
FlameTail
4,384
2,762
So Intel has accepted that Qualcomm is now a competitor. Judging by the slides containing numbers of the 8cx Gen 3.
Hitman928
6,720
12,426
I think Notebookcheck has a really good summary of where MTL stands today. They do mention that the review units they received may not have the final drivers/firmware so potential battery life and gaming improvements possible. Also seem to indicate that retail units won't actually ship until January. I checked Newegg for 155H laptops and there is 1 unit that is supposedly in stock, so maybe some can still get theirs before Christmas.
Intel’s marketing material claims significant power savings while idling and during lighter workloads including Netflix streaming, which is supposed to be handled by the two LowPower efficiency cores of the SoC tile alone, so the compute tile can be turned off. We will try to check these claims over the next couple of days and update this article accordingly. However, we might have to wait a bit until final drivers and software versions are available. . .
Our preliminary test results of the new Intel Meteor Lake processor Core Ultra 7 155H are rather sobering, especially in terms of CPU performance. Our results are pretty much in line with the reference scores we got from Intel, so software updates should not really make a big difference here. The overall CPU performance is pretty much the same as it was with Raptor Lake, but the new H-series chips now cover an even wider TDP range (28-115 Watts), so especially the multi-core performance can vary significantly between different laptops.
We are still cautious when it comes to the efficiency and want to wait for final retail samples, before we can give a verdict. Our results so far indicate minor improvements of the efficiency under load, both for single-core as well as multi-core load scenarios. However, Intel is still far behind AMD and Apple, even if the efficiency numbers are still getting a bit better with retail units. At this point, we cannot yet say anything about Intel’s efficiency claims while idling and light workloads, which is also the case for the AI performance.
Intel’s Meteor Lake offers a big boost in GPU performance and can also beat AMD’s Radeon 780M. Both the CPU performance as well as the CPU efficiency under load, however, did not change all that much.
The situation is better for the new Arc GPUs, but you have to keep in mind that they are reserved for the new H-series processors. The performance increase is massive, at least in synthetic benchmarks, and Intel even manages to beat AMD’s Radeon 780M. The situation changes in actual gaming benchmarks though, but we believe driver updates can improve the situation. We will also add more gaming benchmarks of recent titles over the next couple of days and test Intel’s XeSS upscaling. In addition to increased performance, the efficiency of the Arc GPU is also better and it is almost on par with the Radeon 780M.
You might think that the removal of the P-series makes it easier to find a suitable processor, but this is not the case. As mentioned before, the H-series chips now cover an even wider TDP range and customers just don’t know what performance they will get. AMD’s Zen4 processor (4 nm) is still the better choice in the lower TDP range (28 Watts) and the cooling solution does not have to deal with immense short-term power limits. Apple raised the bar even further with the new M3 generation (3 nm), both in terms of performance as well as efficiency.
We are also a bit worried about the Core Ultra U-series chips, which are still equipped with two performance cores. They were hardly mentioned in the press material and the do not get the fast Arc GPU, either, but only a slower version with 4 Xe cores, which might offer the performance of the familiar Iris Xe Graphics G7 (96 EUs).
We will try to update this article with more data as quickly as possible, but it looks like we will have to wait until January before we get our hands on retail devices with Meteor Lake.
Tup3x
1,281
1,410
I was about to say the same. A bit funny how they are trying to flex against obsolete and ancient PC Snapdragon... Maybe they are a bit scared that things may not go the way they want in the near future.
TESKATLIPOKA
2,696
3,260
Meteor Lake is out and I am not awed one bit, more like disappointed.
What happened to very high base clocks? I was so naive to believe in that.
IGP is also not as good as I expected based on notebookcheck analysis.
Prices are also out and It's not cheap in my country. Cheapest is Lenovo IdeaPad Pro 5 with Ultra 5 125H + 16GB + 512GB + RTX 3050 for €1219.
Good news is that I don't have to regret buying a Phoenix laptop today.
Lenovo IdeaPad Pro 5 14APH8 with 7840HS + 32GB + 1TB for only €981 taxes included, I think It was a great buy for that money.
Hitman928
6,720
12,426
He also mislabelled the AMD laptop as 75Wh, its actually 67Wh, which will make it more competitive with Apple but obviously Apple still leading by sizable margin.
Here are the results, with the AMD battery correction, normalized to a 75Wh battery. Still, without more details on testing conditions, not a whole lot of insight to be had.
