Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 166 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
820
785
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
Timorous
1,976
3,861
Seems Intel is back in the game, at least for the iGPU.
One primary reason for getting a Radeon laptop just went whoosh!
My condolences, @adroc_thurston
That single core score is not great, a regression from RPL?
Also let's see how the iGPU manages in actual games since Intel seems to do relatively better in 3D Mark.
inf64
3,884
4,692
I still vividly remember MLID claiming MTLS having (supposedly) some insane IPC targets of 10-25%, while having much better power efficiency. By now we all know that IPC is pretty much the same, while power efficiency is not impressive at all. MTL is turning out to be a turd, except maybe the iGPU part, which finally can challenge Zen 4 APUs. Battery life is also abysmal, so I don't see how this thing is a better laptop part than RPL or Zen 4. Makes you wonder how screwed up intel execution is, with all those resources they have.
Reactions: Tlh97
Hitman928
6,693
12,355
Battery life numbers (if true) weren't good but I will say that battery life is probably one of the last "performance" metrics that get dialed in with laptops and can be absolutely crushed by immature drivers/firmware. I'm still not that hopeful for MTL at this point, but battery life is the area that I would say has the highest chance of coming out better than what the leaks have indicated, don't have long to wait now.
FlameTail
4,384
2,761
MLID has been heavily saying in his recent videos that MTL efficiency is not good, and that laptop makers will be using AI as the main selling point for MTL laptops, not performance or efficiency.
18,839
I'm thinking it will be close in games even if it can't outright beat 780M. Raytracing might also be better though waiting for benchmarks to confirm that. But it's a good development in general. Games finally move a bit forward in the lowest setting graphical fidelity. Hopefully AMD fires back with a more powerful APU and not content with just keeping parity with Intel's graphics performance.
cebri1
373
405
MTL was never about delivering better performance on CPU side, back in September Intel was asked directly about the p-core and they said that Redwood Cove was a port from Raptor/Golden Cove with no IPC gains, with some minor IPC gains on the e-cores.
The 12500H boost to 4.7Ghz while the 125H only delivers 4.5Ghz. Normalize for frequency and the result difference in CB20 is under 3%, so within margin of error. If MLID said that MTL was going to provide a huge boost he was lying, as always.
MTL is about performance/watt. So far the only thing we know is that there are no efficiency gains at 65W but we are comparing a 45W TDP chip with a 28W TDP chip. Let's wait for official reviews at different power levels, if MTL performs the same as RPL at 30W then it's very bad news for Intel, if it beast RPL by at least 10% perf/watt then they are in the right direction.
TESKATLIPOKA
2,696
3,260
Raytracing should be better, but there is not enough RAW power.
Doom Eternal should be playable >25FPS even with RT on.
mikk
4,293
2,382
9000 points in Firestrike with a 7 Xe core Arc (125H 65W), 8 Xe Arc in the Lenovo leak got 10K points, roughly 10% difference between 7 and 8 Xe cores.
Geddagod
1,513
1,613
If you listened to MLID, that's on you lol
I thought it was better than Zen 4 iGPUs?
Are we sure it's just abysmal? Not apocalyptic? Horrendous? I mean if we are going to use hyperbole, why not go all the way?
Better battery life, AI capabilities, much stronger iGPU. It doesn't look like it's better than Zen 4 tho.
Ice lake just vibing in the corner.
I think Intel's physical design team is cooked or something, idk.
It's a terrible sign for GNR if RWC in MTL is no more efficient than RPC.
Reactions: trivik12
RTX2080
335
535
GNR might not be bad, all I've heard one of the reason why MTL efficiency miss target is all between the Tiles, which is a very early design and complexity is out of control, and it needs to be fixed in ARL.
Heh, and how much more expensive is it? I have my popcorn ready and waiting.
It's an old rumor. Intel4 is 80% more expensive than TSMC N6. But we don't know how much it would cost lately when compared to N5/N4.
some gossip suggested Intel4's manufacturing cost is ~1.8x times of TSMC N6's cost
Reactions: Tlh97 and Exist50
Tigerick
820
785
Yep, that's what I suspected. Each tile needs their own power tail for current and SoC tile needs 3 D2D to maintain constant connectivity. The power penalty would be pretty high, that's why Intel try to put Atom LPE into SoC and hope that the system would shut-down tCPU and tGPU tiles. But I am not sure OS would work with the design and as soon as you wake up the system, all tiles need to wake up again....
That's why I am not sure ArrowLake would solve the design issues. And that's the reason Lunar Lake, Panther Lake and Nova Lake are all reducing the tiles from 4 to 2 only...
Geddagod
1,513
1,613
Should be easy to figure out, if MTL reports core vs package power, I think?
Geddagod
1,513
1,613
I don't think it's the foveros power penalty tbh. But we will see soon ig.
cebri1
373
405
RWC = RPC
Confirmed several times already. That's why when people talk about regression from RPL to MTL when frequencies do not match, people are either trolling or ignorant.
Tigerick
820
785
If monolithic, SoC only needs to maintain one power curve. With 4 tiles, then the system needs to maintain 4 power curves. And I believe there is min V to maintain the connectivity, that's why power penalty would be pretty high....Any electrical enginner want to pitch in?
Geddagod
1,513
1,613
RWC = RPC
On a new node.
What?
Even in a monolithic system, the iGPU might have a different ideal power limit than the cores part of the CPU. Idk what you mean by this exactly.
True, but I wouldn't think it would consume an extreme amount of power or anything. Foveros looks to be pretty efficient, at least that's the impression I got from hotchips
cebri1
373
405
On reddit it's titled "exclusive performance first look" so hoping we get something interesting
I'm not expecting much, at first I though it was scheduled for tomorrow after they unveil the new processors, which would have been a nice touch from Intel to provide additional transparency. But doing it before the event... I mean I'm not expecting anything mindblowing performance wise, I do want to see the GPU in action and also see what the NPU can do, but perf/watt numbers in the 25-45W range is what I'm most interested in.
Mopetar
8,474
7,708
So when exactly is Meteor Lake dropping?
It's 13th December today.
Supposed to be the 14th, so tomorrow. No idea what the product availability will be like, but there should be enough for people itching for something to stuff their stocking this Christmas.
