Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 165 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
820
785
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
H433x0n
1,224
1,606
posterity.
How about waiting until the 14th? If efficiency improves by 15% at 45W they’ve arguably won client mobile until Strix. If Intel gets MTL efficiency within margin of error of Phoenix they likely hold onto their market share for 2024.
They’ve got more volume, more resources for supporting OEMs and the ability to sell cheap lower end RPL dies.
Abwx
11,868
4,846
The leak say 12k pts in CB R23 at 40W, same score as a 13700H@45W and a 7840U@30W, that fits in a +33% error margin, the 7840U@30W does exactly 12385 pts, so that put it at barely 28W for 12k pts.
H433x0n
1,224
1,606
Let’s wait until the 14th.
The 13700H is a 45W process being compared against a 28W MTL lower down the stack. It’s replacing the 1360P, not the 13700H.
gdansk
4,463
7,529
I'll wait a bit more. Laptops are all over the place based on cooling solutions and vendor-chosen power limits and boost times.
Plus that's a cutdown variant so maybe more cores will help.
H433x0n
1,224
1,606
What's bad exactly? The minor single core performance regression? Since in all other points the Ultra5-125H is showing better performance than the i5-13500H despite running well above its target TDP.
The iGPU performance looks good but even that I’m pretty skeptical of until we get proper data.
No clue why 65W was chosen either, at 65W the 13700H would appear to be close to Phoenix in efficiency and it’d be totally misleading. In this context it’s okay since it means you can dunk on MTL though.
Philste
297
474
So MLID was right about MTL efficiency?
Nobody knows of these are ES or final Silicon. Let alone the fact that 65W is probably too high to really compare the CPUs. MTL might bring 95% of that performance at 35W, where RPL only brings half of it. It's like Comparing Phoenix and Rembrandt at 95W. Both pretty much Max out at 65W and below, so at 95W the performance is roughly the same.
Saylick
4,005
9,402
Not a particularly relevant one since Intel primarily lacks on CPU oomph/W and battery life and MTL solves kinda none of that.
If so, I'm sure some one out there will highlight the dual encoders/decodes and cite it as a reason to buy MTL over HWK.
Abwx
11,868
4,846
That s impossible, 95% of the perf@65W is obtained in the 56-57W range, there s a curve posted by HXL, and it s apparently 95%@57W when looking at the slope from 28 to 65W.
H433x0n
1,224
1,606
The graph with no y axis and has no baseline comparison to 13500H.
Khato
1,275
351
It's a dieshrink tied to an overall a lot more expensive product that showcases a perf regression over the cheapness that is RPL.
Heh, and how much more expensive is it? I have my popcorn ready and waiting.
MTL regression on single thread performance versus RPL is indeed unfortunate. But last I checked RPL was already well on top in that particular metric anyway. It's efficiency (and by extension MT performance) where RPL is a bit behind what AMD has to offer. Where MTL lands in that pursuit? Well, hopefully you need only wait a few more days now. (Can at least hope that review samples are provided in advance of launch.)
H433x0n
1,224
1,606
There’s MTL benchmark leaks that show the opposite with the Core 9 185H ST performance in line with expectations. In general ST performance will depend on clocks since IPC is relatively the same.
Reactions: cebri1
Abwx
11,868
4,846
The comparison with the 13500H is irrelevant in respect of what i said, wich is that this 4 + 8 need 56-57W to perform 95% of its 65W perf.
The graphs say that perf increase by 47.1% when power increase by 132%, that is , from 28W to 65W, from here you can extract the power/frequency curve in this segment :
Power = F^(ln(2.32)/ln(1.471)) = F^2.18
So at 0.95x the frequency power will be :
P = 65 x (0.95^2.18) = 65 x 0.894 = 58.1W
Obviously this chip was tailored to reach high TDPs, assuming this curve is accurate, wich is no surprise since current 4 + 8 can reach way higher powers than 65W.
18,847
Seems Intel is back in the game, at least for the iGPU.
One primary reason for getting a Radeon laptop just went whoosh!
My condolences, @adroc_thurston
Reactions: FlameTail
FlameTail
4,384
2,761
yeah screw AMD with their good APUs being barely available and mostly relegated to high end gaming laptops which have a dGPU anyways.
Intel will be our saviour thanks to their immense volume and influence.
Obligatory /s
gdansk
4,463
7,529
If you scroll up a bit, he already posted this and says it means MTL is a flop.
In either case it's probably best to wait for testing at MTL's target power limits.
And if it's like other Intel GPUs it'll kill in benchmarks then flail around in actual games.
