Page 144 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
919
834
Dies2221
Threads8688
Max Clock3.8 GHz?5 GHz
L3 Cache6 MB?12 MB
TDP7 WFanless ?17 WFanless
Size16 GB?32 GB24 GB ?
EU / Xe32 EU2 Xe8 Xe12
Max Clock1.25 GHz2 GHz
NPUNA18 TOPS48 TOPS100 TOPS ?
dullard
26,185
4,841
Yeah but MTL already looks like a poor product with the LNL leak. Jump from 6400 to 8533 MT/s RAM is reason enough to wait one more year.
Need to know timing, pricing, availability, and more importantly: core counts needed. Sure, if you are looking for a fanless or otherwise low power computer, MTL-U is going to be overshadowed by LNL-MX. But, if you need a lot of cores for large multi-threaded applications then LNL is not the type of product for you. In that situation, a 16 core MTL-H with at least 45 W of power will do far more than an 8 core LNL-MX with far less power available to it.
19,203
True. However, what would be interesting is if the LNL-MX's newer iGPU can beat the MTL iGPU due to higher available bandwidth.
Thibsie
1,156
1,363
More BW and capacity on the higher end SKUs than Apple M3. Same CPU config - 4P+4E as the M3. If Apple stagnates on P-core gen on gen performance improvements, and Intel gains momentum with Lunar Lake MX and its followers, Apple is gonna regret going the ARM route.
No way they will regret a thing. They no longer depend on intel and control their CPU too now. When you want a closed system, that's exactly what you want to do.
tamz_msc
3,865
3,730
I mean when others have reached parity in perf/watt. I know that despite the marketing, Apple's real aim was vertical integration.
19,203
I don't see why Apple can't have two MacOS builds, one for ARM and one for x86. Intel for MBA and their own SoC for MBP.
What if there's an LNL prototype on their campus right this instant? :p
Saylick
4,099
9,578
I was about to make a joke, but then I decided to check Videocardz and the joke had become reality:
Haha, I've always wondered. If one were the only remaining source of leaked slides and then put an obvious and legible water mark that said "*insert your favorite rumor mill site* can suck my ...", would they go ahead and write an article using those slides?
Thunder 57
4,206
6,993
Arrow Lake CPU tile is 20A. Granite Rapids is 3nm. Lunar Lake is obviously catered to premium ultrabooks that compete with Macs, so it will be low volume. So the most important products are still on Intel nodes.
And I don't think that 5 nodes in 4 years means Intel will have lead products in segments for each of those nodes. The plan is to regain process leadership.
So by going with N3B they are going to regain process leadership? That doesn't make any sense.
Also, why are they sitching their SoC CPU cores already? Guess they didn't work out as planned.
Reactions: Joe NYC
jpiniero
17,006
7,406
The plan is to try to convince Wall Street that they will regain process leadership.
They still have to sell products.
Geddagod
1,617
1,665
I'm guessing SOC CPU cores will remain on mainstream mobile parts as long as the SOC, CPU, and GPU tiles are split there. So MTL and ARL.
TESKATLIPOKA
2,696
3,260
8533 MT/s offers 33% higher BW, but that alone means nothing.
You need to know the performance of both IGPs and If they are bottlenecked or not.
The amount of Xe is the same.
IGP's architectural gain is unknown.
LNL with 8Xe will be clocked at 1850MHz, that's not particularly high for a 30W chip.
For example, 7840U at 25W manages 1833MHz in Witcher, but has less execution units(768 vs 1024).
It will be interesting to compare It to Strix Point limited to 30W, which will have a comparable 16CU(1024FP32) IGP.
Reactions: Joe NYC
H433x0n
1,224
1,606
AMD is using Samsung to fabricate Sonoma Valley - does this mean TSMC is screwed and Samsung has process tech leadership? AMD is one of their biggest customers and previously used TSMC exclusively.
adroc_thurston
7,886
10,604
For cost-sensitive markets? yea, TSMC gotta step up now that their utilization rates ain't sky-high anymore, especially on N7.
That's the narrative, in reality Intel wants to offer foundry services as a future node cost amortization pipeline.
Tigerick
919
834
Sonoma Valley is just a low-end SoC replacing 7020 Zen2 APU with most likely having 4 x Zen5c to compete with Intel N-series. The real challenge for AMD is how much TSMC's allocation of N2 process AMD will be getting ...hopefully Intel will get their own node in time with Intel Next process.
AMD is using Samsung to fabricate Sonoma Valley - does this mean TSMC is screwed and Samsung has process tech leadership? AMD is one of their biggest customers and used previously TSMC exclusively.
Thunder 57
4,206
6,993
I was pointing out the tortured logic and trying to bring some nuance - I wasn’t actually serious.
Tortued logic? More like crap comparison. There is nothing wrong with dual sourcing. They can push out more products that way. They probably got a decent deal from Samsung too. They could very well use SS for lower end CPU's, APU's, or GPU's. That would leave TSMC for the higher margin stuff. If Intel 20A or 18A was any good and on time, they would use those. Instead, Intel is using N3B. That's not a good look.
Tortued logic is you thinking I believe TSMC is screwed and SS has the best nodes. AMD has used multiple fabs before. They have used GloFo and TSMC at the same time for different products. I believe they even used SS a bit as well.
H433x0n
1,224
1,606
Okay.. I'm with you so far
Should they hold off another 6-9 months on Lunar Lake so it can be fab'd on 18A for better PR and internet points or launch their mobile processor on a very efficient TSMC N3 node? It seems you're suggesting the former.
I don't think that at all.
