Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 137 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
784
753
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
18,250
Wasn't it a given that actual availability of Meteor Lake in Q4 2023 would be nearly non-existent and very expensive?
True. But I get why the OEMs might be furious. Intel announced MTL officially so a lot of people may have put their laptop buying plans on hold to get the latest Intel thing. So not only do the OEMs not have MTL laptops to sell but what they do have in the channel may also see decreased sales. Intel double whammied them.
poke01
3,911
5,226
Hulk
3,664
Comparing mobile parts even after official release is hard enough because every system throttles to some extent. Trying to compare them before release introduces even greater variability since we don't know if these are retail parts QS, or whatever, we don't know clocks, memory subsystems, etc... I suggest we wait until release before we start arguing about what a giant fail or success this is for Intel.
Reactions: yuri69
poke01
3,911
5,226
Yep, will reserve my opinions till release.
SiliconFly
1,925
1,284
A
It's been like that pretty much through the entire Zen era. AMD ships some mobile SoCs but you never really know where they're going. Availability at retail is bad for months on end.
Actually, you can find excellent AMD laptops in Alienware, Razer Blade, Asus ROG, Acer Predator, Nitro, HP Omen, etc.
Thibsie
1,094
1,275
A
Nah, those are gamer bricks using heavier PSU than the laptop itself (yeah, I pushed it but you get the idea).
Thin & Light yet performing (relative to their thin & light constitution of course) is a lot harder.
Reactions: Tlh97 and Hulk
tamz_msc
3,865
3,730
Geekbench 6 is calibrated to give 2500 score on a desktop 12700 in the ST tests.
Since it is performing essentially the same as a desktop 12700, considering the variability of Geekbench runs on a laptop, I would say it's performing as expected.
The MT score is really impressive, considering 8+4 for the 12700 vs 6+8 for the Meteor Lake chip, with the obvious caveat that it's not known what the LP Island E-cores do when the CPU is run at full tilt. Lower boost frequency of the E-cores in general may also be a factor.
18,250
I read that they generally do not take part in MT workloads unless you force them to participate through process affinity. Even then, their contribution to the MT performance is nothing to write home about.
18,250
mikk
4,292
2,382
ST is worse on MTL. Because of the same IPC and roughly ~300 Mhz less peak frequency it is not a surprise anymore. Also the tile architecture seems to introduce some extra latency over Raptor Lake which contributes to it. ST isn't the most important if it's just a 5% slowdown. Efficiency/Battery life matters much more.
Thunder 57
3,838
6,479
If the reference laptop is any indication of final performance, there is "some" hope for MTL to not be a failure. Notice the MTL chip being on Stepping 4. Got delayed by silicon bug fixes, I guess?
Not that bad compared to a 13700H but still getting beat pretty badly in some tests: https://browser.geekbench.com/v6/cpu/compare/3435865?baseline=2772108
The fact that is loses the single threaded tests but does pretty well in MT makes me think it is more power efficient and able to maintain higher boost than RPL.
Thibsie
1,094
1,275
IMO MTL is more about going to a modular approach with more or less the same stuff than anything else.
I'm not pointing the finger at Intel, quite the opposite: it is wise not to do to much at the same time.
If this is a success on a manufacturing PoV (including yield etc) : good. Intel will move to the next goal.
It is clear though than from a pure performance PoV, MTL isn't earth shattering to say the least but IMO this wasn't the point at all. And it is OK to me.
tamz_msc
3,865
3,730
Also regarding power consumption - the 12700 has a PL2 of 180 W. Considering the 28-35 W TDP of these Meteor Lake CPUs for which I really doubt that PL2 would be set much higher than 65 W (which is a reasonable assumption given that RPL-P chips have their PL2 set at 64 W as per spec), we are potentially seeing ~1/3 power consumption at iso-frequency and similar performance levels.
Tuna-Fish
1,653
2,493
3, 3 wide decoders sounds pretty weird tbh. And one of the decoders is disabled for a total of 8 wide?
Maybe they want SKMT to target extremely low power so they could power gate to just 2 or 3 wide decoders if they want to, idk
I would assume the decoders are 9 wide total, but something right after them is 8 wide. 3x3 decode doesn't get you 9 ops every clock, there will be mispredictions etc. If there's room to buffer a bit between them, if you have for example 8 wide rename, going 9 wide in the decode still probably win you a little, even if it's impossible to maintain 9 ops per cycle every cycle.
eek2121
3,387
5,014
Of course it is more efficient. All these people are dooming it without understanding that the chip sips power.
Also, this isn’t even the fastest SKU. Get back to me when the 185 sku has a good GB run.
jpiniero
16,568
7,071
Same thing happened with Ice Lake. I'm guessing they loosened the bins as far as possible to get enough chips. So it may not be more efficient than Raptor Lake.
SpudLobby
1,041
702
Do we have any more recent indication as to what kind of volume MTL might be shipping? Meme volume sure but anything quantitative or guesses?
Also *when*, particularly for < 35W. I’m guessing we’ll see Q1-Q3 ‘24 for serious availability.
SpudLobby
1,041
702
Agree RE. Performance. Efficiency under load and idle efficiency are just far more important right now
SpudLobby
1,041
702
A
Those are all gaming or beefy laptops. I hope this is facetious about how piss poor AMD is on mobile laptops 15-35W that the average person might want to use lol. It’s still atrocious honestly especially in the US.
