Discussion Intel Meteor, Arrow, Lunar & Panther Lakes Discussion Threads
Page 132 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Tigerick
750
703
Comparison of upcoming Intel's U-series CPU: Core Ultra 100U, Lunar Lake and Panther Lake
ModelCode-NameDateTDPNodeTilesMain TileCPULP E-CoreLLCGPUXe-cores
Core Ultra 100UMeteor LakeQ4 202315 - 57 WIntel 4 + N5 + N64tCPU2P + 8E212 MBIntel Graphics4
?Lunar LakeQ4 202417 - 30 WN3B + N62CPU + GPU & IMC4P + 4E012 MBArc8
?Panther LakeQ1 2026 ??Intel 18A + N3E3CPU + MC4P + 8E4?Arc12
Comparison of die size of Each Tile of Meteor Lake, Arrow Lake, Lunar Lake and Panther Lake
Meteor LakeArrow Lake (N3B)Lunar LakePanther Lake
PlatformMobile H/U OnlyDesktop & Mobile H&HXMobile U OnlyMobile H
Process NodeIntel 4TSMC N3BTSMC N3BIntel 18A
DateQ4 2023Desktop-Q4-2024
H&HX-Q1-2025
Q4 2024Q1 2026 ?
Full Die6P + 8P8P + 16E4P + 4E4P + 8E
LLC24 MB36 MB ?12 MB?
tCPU66.48
tGPU44.45
SoC96.77
IOE44.45
Total252.15
Intel Core Ultra 100 - Meteor Lake
As mentioned by Tomshardware, TSMC will manufacture the I/O, SoC, and GPU tiles. That means Intel will manufacture only the CPU and Foveros tiles. (Notably, Intel calls the I/O tile an 'I/O Expander,' hence the IOE moniker.)
mikk
4,287
2,370
DrMrLordX
22,585
12,467
Given Intel's classic aversion to low console margins, I doubt they'll be making any deals with Valve. Plus Meteor Lake parts are going to be expensive for awhile.
Geddagod
1,343
1,435
MTL should beat Phoenix. MLID was correct...
I wouldn't be too surprised if the iGPU synthetics look pretty good... only to be a lackluster when looking at perf in games themselves. From what I hear, that's the general trend with Intel's iGPUs recently
Also, MTL beating phoenix, overall, as a product? Doubt. Guessing it's going to be close though.
S'renne
139
105
86
Hope its close enough though, but even if it isn't, it still offers similar features I think, and still has more availability than Phoenix later down the line
Geddagod
1,343
1,435
Only reason it might end up having more availability than Phoenix wouldn't be because Intel is pumping out MTL, but because AMD just sucks at mobile volume. I think the existence of RPL and RPL-R mobile and MTL launching so late is pretty indicative of that.
S'renne
139
105
86
I'm just waiting on MTL efficiency benchmarks anyways since my real interest is Arrow Lake, I want a desktop replacement laptop with ARL lol
Reactions: Tlh97 and Geddagod
mikk
4,287
2,370
With a 2x improvement over Iris Xe they can easily match Phoenix. When it comes to 3dmark I would use timespy graphics, I think it needs roughly 3500 points to match Phoenix. This is based on A380 vs RX6400. A380 scores 15-20% higher whereas in real world they are evenly matched. The fastest Phoenix 780M devices score 2800-2900 points. 15-20% higher than this gives roughly 3500 points. I think this is doable for MTL-H tGPU at 2.2 Ghz.
TESKATLIPOKA
2,696
3,259
It probably is doable at 2.2GHz, but what I want to know is the power limit for that frequency.
If 35-45W is enough for that then great, If more is needed then not great.
Geddagod
1,343
1,435
MT score is... questionable, though we don't know what TDP is used
ST score of >5%. Not good, but not bad either. Intel doesn't need a massive ST bump to compete with Phoenix, so it's not too disappointing.
Oh also, talk on Twitter from Raichu +Bionic is that :
ARL-H GPU tile uses N4P, and it has some improvements and is not a complete refresh of the MTL-H iGPU die (doubled L2 and XMX). Though it's not BMG.
ARL-S reuses the 64 EU GPU tile of MTL though
H433x0n
1,224
1,604
What’s considered beating Phoenix overall? You don’t think it’ll manage a 15-20% boost to performance at isopower sub 55W?
Edit: That link you posted has an odd MT score. Crestmont has ~5% IPC increase and most MTL SKUs will have similar (or greater) e-core clocks over RPL. This benchmark had to be power or thermal limited.
lightisgood
242
117
86
Probably, low power limit generates low MT score.
I'm very optimistic about MTL MT performance.
By the way, I have a great interest in 5.6% ST score boost rather than low MT score.
Intel said that Redwood Cove has Rapter Cove's IPC on the whole, didn't it?
I don't think 5.6% ST boost is small difference....
Intel provided sloppy explanation about Redwood Cove, RIGHT?
I'd like to see other ST benchmark cautiously.
H433x0n
1,224
1,604
5.6% ST increase seems too good to be true tbh. I doubt that ends up being a representative result.
Geddagod
1,343
1,435
What’s considered beating Phoenix overall? You don’t think it’ll manage a 10-12% boost to performance at isopower sub 55W?
It's closer to 15-20%, which is cutting it really close. I think it will tie or maybe even slightly lose to Phoenix tbh. Also, in single core perf/watt (for RWC), I believe it will be worse there as well.
In iGPU, it appears to be better
In battery life, I mean Intel claims 2x, but that's highly dependent on how they test battery life. I expect a massive improvement, but there's a lot of ground to cover too.
And in ST peak performance, I expect them to be roughly tied.
This isn't an overall win over Phoenix, since they have some areas where they might lose (albeit slightly) or be tied in. What's even worse is how much later it's coming compared to Phoenix as well, and how much more expensive it looks to be too. At best one could say this is a slightly buffed Phoenix, depending on what metric you are comparing it for.
S'renne
139
105
86
Btw doesn't Meteor Lake's NPU has better software support than AMD's Xilinx NPU from their demo? They at least also have better software support compared to AMD in that area
Geddagod
1,343
1,435
Tbh completely forgot about the entire AI element of both Intel and AMD mobile chips. No idea ¯\_(ツ)_/¯
TESKATLIPOKA
2,696
3,259
Phoenix requires more than 50W to reach 2800-2900 points, the fastest one use 70-80W.
You don't need that much power.
Ryzen Z1 Extreme => PL4:53W, PL2:43W, PL1:30W
Time Spy Graphics: 2854 points
PL4 duration is ~10s
PL2 duration is ~450s
TimeSpy will finish within PL2 duration, so 43W highest for Phoenix.
Comparable performance at ~45W would be great for Meteor Lake.
Reactions: Tlh97
H433x0n
1,224
1,604
I'd take that outcome tbh. Phoenix is on N4P, arguably the best TSMC has to offer at the moment. It's also going against Zen 4, probably the best overall core design in the past 10 years. If it matches Phoenix efficiency (+ or - 5%) I would say that's the best position Intel has had in a while especially since they can actually provide volume and support.
mikk
4,287
2,370
This is a special binned and tuned model for handheld only. In a regular notebook most OEMs go for performance to gain just a few percent which require 20-40W more power, although I would expect a handheld OEM even with a regular SKU won't be so crazy.
He also said the GT3 version had been cancelled. This was expected to me. GT2 with unchanged 128EUs is disappointing if true. This comes with a limited increase in GPU performance in the next generation. ADM is also unlikely without GT3. It's a poor execution that they couldn't switch to Xe2, Lunar Lake gets it in a similar launch timeframe.
