Page 633 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Hail The Brain Slug
3,890
3,331
I see a lot of variation here in CBR23 scores. Might be down to memory, but I think 26k is on the slow side for 5950X.
In any case, until we see more numbers it'll be hard to know exactly what 42% faster is . . . but then we haven't seen any numbers at all for 8+16 Raptor Lake.
Actually not really. The only bearing memory has on a 5950x for CB R23 is higher FCLK/memory eats into the limited power budget and forces lower clocks. At stock jedec 2133/1066 FCLK I will see slightly higher all core boost and around 26.5k scores. At my preferred 3800/1900 FCLK I get lower boost with stock power limit and see ~25,500.
It's entirely limited by power, and no other reason on a CPU stock config.
MarkPost
378
794
A nearly 29K score in R23 for the 5950X requires an overclock to 4.5 GHz all core. I'd be surprised if AMD is claiming the 40+% over that, more likely it's against a stock 5950X that scores in the 25.5K range.
A 5950X @4.5 scores above 30k
TESKATLIPOKA
2,696
3,260
I think a lot depends on what clocks they can achieve in 10W per core region with CB23 load. It takes Intel ~15W per core to achieve 5Ghz on P cores, so i would not be surprised that AMD can hit 5Ghz on new process @ 10W.
Bodes well for me anyway, as i run 3950/5950 at fixed clocks and undervolts.
ADL P-core doesn't consume only 15W per core to achieve 5GHz.
Blender
That's >30W per core for less than 5GHz.
~15W per core means only 4250MHz.
Reactions: lightmanek
JoeRambo
1,814
2,105
Blender is a quite a bit different workload than CB23, more demanding. Still stock CB23 would not use 15W for 5Ghz either.
I am using my own undervolted and fixed @5ghz cpu. Running @ 5Ghz CB23 it is 130W without HT. Would be more in Blender i believe and HT would add some more. But still in ballpark of 15W per core for 5Ghz.
Stock settings and 12900K SKU never really made sense, between 125W and 283W there is 7% gain in score for blender, awesome deal.
And there is another interesting points on that graph: 65W 8+8 scores the same as 125W 8+0. 125W 8+8 is 33% better than both of those. 8+16 would go ballistic with score already, beating that 283W abomination @ 125W.
TESKATLIPOKA
2,696
3,260
You didn't mention, that you were talking about an undervolted ADL and HT was off.
JoeRambo
1,814
2,105
My fault, sorry if that made an impression that out of box 12900K can somehow hit 5Ghz on P cores on such low power.
That is simply not happening cause Intel was not caring about efficiency at those operating points for this SKU.
During manufacture of chip several things happen that ruin any illusion of operating properly at lowest possible power at any given point:
1) Each core is characterized and has it's v/f curve determined. So in our 5Ghz case what matters is last three points. 42x, 48x and 53x ( later mfg date 12900K will have 52x instead of 53x as so called "OC ratio" ).
2) Each cores values are written to chip and are then used to interpolate voltage required at any given operational point.
During operation, largest requested value is selected out of active cores, so if a chip has a lemon core that cannot do 53x without 0.05V more than best core ( but would work perfectly @ 5ghz at same low voltage as others) => bad for you.
So at any point other than 48x or 53x we are at huge disadvantage already and 50x is esp hurt since it is far away from 53x, and yet quality of chip at peak frequency determined how much power it will eat at lower freq.
Later on after this voltage is decided by interpolation @50x, the usual guard bands for AVX, for motherboard VRM quality and so on are added and we arrive at ridiculous voltage that has nothing to do what this particular chip would really need on this frequency. Then feedback loop of TVB happens where chips voltage gets corrected by raising temperature to keep it stable.
Power usage goes ballistic, freq is dropped, but temps are stuck high, so is TVB correction, further inefficient points are selected and chip will eventually settle down on 48-49 if load is low enough or drop down to 42-43 if it is brutal as shown by ComputerBase in Your article.
Back to our original discussion -> 5ghz is just a point I happen to be running, it is in no way in most efficient part of operation for GC core in 4-5ghz range. But ballpark figure is that Intel would need ~15W @ 5Ghz to run CB23 for GC cores and we will see how much AMD will need. I am running 5950x 4.4ghz in low 1.1x regime, so we'll see how 7950x will do.
Timmah!
1,572
935
If its SPR, then its disappointing. Just yesterday i read, granted on WCCF, that SPR Xeons-W are coming in October, including that mainstream ”hedt” line-up topping at those rumorex 24 cores. So maybe theyre not really and its just another unfounded rumor.
ashFTW
331
252
The bug may affect only the SPR Xeon scalable (non monolithic), and not SPR Xeon-W (monolithic). Maybe it’s related to Optane or CXL or something that‘s not supported on Xeon-W
DrMrLordX
23,227
13,309
Xeon-W Sapphire Rapids will allegedly have two dead tiles and two 12c tiles. If I recall correctly? Anyway it should be much easier for Intel to ship this product than a full server-class Sapphire Rapids.
What makes you think the Xeon-W will be monolithic?
That's odd. My 3900X @ default clocks outperforms most other 3900X results out there in CBR23 (mine just got a 19423 in a throwaway run with browser still open). I always chalked it up to the memory tune.
Regardless, it looks like the power numbers on that Raphael 16c demo are now up in the air, so comparing it to hypothetical upcoming Raptor Lake 8+16 is now even less fruitful. Even if it is 42% faster than a 5950X, we don't know at what power (it's less than 230W, that's all we know).
Timmah!
1,572
935
This is probably the most likely scenario, but why there would need to be those dead tiles again? Why not just 2 12 core tiles connected via that EMIB bridge?
There was MLID rumor this will be the case. We shall see.
Personally i found both options (2 x 12C tiles) and monolithic 24 core rather weird. If one tile is 15 core, why are they capping it at 12 core and thus 24 core for entire SKU? Surely they can produce fully functional 15 core tile? I find it difficult to believe, the top "product" would not have 2 uncut dies. Was it not the whole purpose moving to this tile solution to improve the yields, so they can produce higher core-count CPUs?
The monolithic 24 core CPU then, unless again thats cut-down, is rather weird number, as it does not make much sense, if you are trying to figure out the "grid" configuration of the cores.
All of it sounds to be somewhat bogus.
DrMrLordX
23,227
13,309
Someone explained it, it went in one eye and out the other (?!?!) so sorry, I just don't remember.
Um, well, uh . . . maybe?
When was the last time Intel went over 8c Cove on any of their 10nm nodes? IceLake-SP. Look at how THAT turned out. Woof.
ashFTW
331
252
The max 60 (15x4) core SPR chip is made with four XCC chiplets. In this design, a significant amount of space is used on two edges of these chiplets to bridge (using EMIB) the mesh from one XCC chiplet to the next.
How do you think they will make lower core count (say 28) chips? Definitely not by disabling half the cores on XCC chiplets; that’s too wasteful. Also not by using 4 smaller chiplets; the area dedicated to EMIB will dominate even more. It would be much more cost efficient (total silicon used, and yield) to make smaller MCC monolithic chips at the lower end. And, these can also be repurposed for Xeon-W.
But it’s also possible that SPR won’t offer low core count chips (say below 40), and that slack is picked up by IceLake. We have to wait and see…
jpiniero
17,205
7,580
There definately will be sub-8 core per chiplet Metal Xeons.
Volume of Xeon-W isn't much. Partially busted EMIB models should be enough to satisfy the demand.
nicalandia
3,331
5,282
Correct, some misguided folks here think that Intel will go to the trouble of making a Single 24C/48T Monolithic die
This is what I predict it will look with two 12 Core tiles and two dummy Silicon Tiles for suport
A 24C/48T Sapphire Rapids CPU has been listed by YuuKi_AnS which is a good source
ashFTW
331
252
There definately will be sub-8 core chiplet Metal Xeons.
At that point, it’s better to make a monolithic chip -- less silicon used, simpler design, and better yield.
Yes, but the volume of low core count chips is huge. And those chips are being repurposed for Xeon-W.
