Question Intel Core i9-10980XE Can Hit Up To 5.1 GHz OC Across All Cores with "Standard Water Cooling"
nicalandia
3,331
5,282
Is that with the 1 HP Water Chiller that was used before?
Reactions: DarthKyrie
amrnuke
1,181
1,772
"And that, I believe, is all cores. "
So even Intel doesn't know if it's all-core.
Also, not sure why they're using GeekBench to compare HEDT chips, when the test doesn't scale well across cores and is entirely too synthetic to be of much use. Even then, the WCCF image is sourced from an unsourced HotHardware "leak" of results.
amrnuke
1,181
1,772
Compare that to the celebration in the other thread of a 16c 3950x managing an all core overclock of 4.3GHz on water.
Exactly... and it's like... neither of these chips are released yet. Let's just chill out a bit and see what happens.
Kenmitch
8,505
2,250
I'm sure we'll see where it sits on the HEDT scale once it's released.
Only thing I can conclude so far is they wouldn't cut the pricing so drastically if they thought they had a clear winner in the end. I guess we'll see the good, bad, and the ugly once they're released along with AMD's offerings. The reviews should at least be interesting....The action will be in the comment sections!
The weird part is it looks like they intentionally avoided equal core counts to AMD's offerings.
DrMrLordX
23,149
13,246
Probably not. Intel used the chiller on a 28c chip that eventually became the W3175. That thing is infamous. This thing will probably "only" put out ~500-600W under the same scenario.
Lets see the power consumption numbers. 5ghz all core under 200 watts i be really impressed
Here's the 9980Xe @ 4.4 GHz:
Under 200 watts? No.
Reactions: IEC
positivedoppler
1,148
256
so if 4.4 ghz is 384 watts, 5ghz is 400-500 watts? How do you cool that?
Markfw
May 16, 2002
27,374
16,216
As the title says "standard water cooling". 2 420x140 thick rads will provide maybe up to 600 watts. Put a solid copper CPU block, and 6 decent fans and a good pump. I have almost exactly that same setup on one of my 2990wx's, OC'ed to 3.8. It will do 4 ghz, but the temps are getting up there, so 3.8 is pretty good all core 24/7 100% load.
But this 18 core beast@5.1 I would guess is in the 500-600 watt range, so the same cooling I have (mine is only 350 watts@3.8) should do. I run 70c, and their setup on my cooling would most likely be 90c.
Its really hard to extrapolate, so don't hold me to any of this. Just an educated guess.
Ajay
16,094
8,114
“There’s no refrigeration unit, there’s nothing like that,” Walton reassures us. “When we say ‘standard liquid cooling,’ I don’t know the specific one, but nothing out of this world.”
Anyway, this is just early PR, probably based on a 'golden' sample. Outside of professional overclockers and YouTubers, no one is going to doing this.
Accord99
2,259
172
Gamer Nexus' review of overclocked 7980/9980 XEs shows that 400-500W from a die that's 450mm^2 big can be cooled with a 280mm CLC.Though what Intel really needs to do is spend some money to manually liquid-metal the processors at the factory.
Another way to look at the 10980XE is that if 5.1/all-core is "achievable," then something like 4.8/all-core should be possible for most enthusiasts without resorting to exotic techniques and equipment.
john3850
1,436
21
With a room temp of 67 I can run blender at 174 watts or 5.0GHz with vcore 1.31v I hit 70 with only one of 3 radiator fans maxed out.
Now summer time next to small ac would be close to 85c.
Zucker2k
1,810
1,159
Launched.
IEC
14,606
6,094
Launched.
For a "launched" product, it's conspicuously absent from retail channels. I don't even see it listed as a product on distributors' websites.
Isn't it expected to be shipping in November?
jpiniero
17,045
7,442
They may have started to send product to OEMs.
VirtualLarry
56,587
10,225
Sounds... interesting? Well, for the Intel aficionados anyways. They've largely lost my business personally, though I'm not against building an Intel rig for someone else that specifies a preference (as long as they're paying, LOL).
Topweasel
5,437
1,659
That's not gonna happen, not even close.
Yeah doesn't the 9900k at 4.6 use ~160w? That's without the extra cache and mesh power. Best case you double it (for 2x the cores) then add 33% to get the last 500MHz. So we are talking about closing in on 400w. Worst part is there isn't a great power savings when shutting off cores for each die so the 12c and 14c chips will all be hovering above 300w. Now this isn't impossible to cool, but it isn't going to be easy. It's pretty much all going to require multi rad loops.
Shmee
8,313
3,177
I liked the 5930k, that is a good HEDT chip. All these new ones have too many cores and likely wont't do as well in games as an OCed X99 system.
Topweasel
5,437
1,659
Its hard to say. SL-X is significantly down on game perf compared to a SL clock for clock so it really matters how high you have yours. But the core count isn't what is going to hold it back.
DrMrLordX
23,149
13,246
Actually, due to voltage and clockspeed scaling, I would expect that 5 GHz Cascade Lake-X to push over 500W. Which is not unheard-of since a 2990WX can get up there as well. As to what you would use to cool it . . . well, I have this thing called a MO-RA3. It's pretty nice. It can cool 200W loads with no fans.
ehume
1,511
73
I just looked up the MO-RA3. It looks to be a 3x3 (9 140mm fans) rad, with copper tubes and aluminum fins, "optimised specifically for low-rpm fans." Works, huh?
