Techspot. Go search yourself. 😉
12W lower power consumption under load than the 25W Athlon 5350. Probably a different MB+J1900 combo than the one used in the AMD-biased review you picked.
12W lower power consumption under load than Athlon 5350. Probably a different MB+J1900 combo than the one used in the AMD-biased review you picked.
Indeed, I mentioned the same thing on page 1. Different motherboards can make a huge difference. Example : AMD's 5350 uses less power idle than a 10w J1900 Celeron in OP's test, and yet 20% more power idle & load than a 60% faster 17w i3-3217U (NUC D33217CK) in another test:-the only useful analysis you can make with these numbers is to compare idle vs load, because TDP is not supposed to cover the entire PC,
also you are comparing different motherboards, even if you try to keep the rest unchanged, and it can make a huge difference for low TDP CPUs
Well, the TDP cannot be measured from power consumption graphs. It is the same thing with the FX CPUs that people got fascinated with a few months ago.
Those graphs posted above, measured Power Consumption for the entire system, idle to full load delta also doesnt provide any meaningful data towards TDP evaluation. It only shows how power efficient the platform is to lower its power consumption when Idle.
And for the Billionth time, TDP is not power Consumption.
Do note, though, that TDP isn't about power consumption specifically, but rather the maximum heat the cooling system needs to dissipate.
Idle / CPU Load difference:
- Celeron J1900: 5W
- Athlon 5350: 16W
- Celeron J1900: 5W
- Athlon 5350: 15W
- Celeron J1900: 4,4W
- Athlon 5350: 16,7W
Now Cinebench 11.5 performance:
Celeron J1900: 1.8
Athlon 5350: 2.0
http://us.hardware.info/reviews/533...ap-desktop-platforms-benchmarks-cinebench-115
What did you say again? 🙂
Mods have been very tollerant with him, hardly adds something useful and usually derails threads and gets involved in flame wars.
Well you read it, so just tell us what the power supply was? Isn't it appropriate to link to the site you are linking to? Are you trying to hide something?
The reason I'm asking is because almost all of the reviews of the 5350 were using ridiculous power supplies that are completely over speced. And you were cross referencing charts with an appropriate pico power supply to something that we don't know and hodgepodging it all together.
idle Videoplay Videoconv. gaming
Athlon 5350 + ITX-Mainboard 8,0 Watt 11,0 Watt 21,0 Watt 20,5 Watt
Celeron J1800 + ITX-Mainboard 9,0 Watt 10,0 Watt 16,5 Watt 15,5 Watt
Celeron J1900 + ITX-Mainboard 12,0 Watt 13,0 Watt 20,5 Watt 19,5 Watt
What is the difference? That's a serious question. Is that even measurable? How much of the consumed energy does not end up as heat? The chip does not do any mechanical work so I'd wager that it is something in the order of milliwatts at most.
How can it be idling at 0 when the compared chip is idling 7W lower?
If Silvermont were idling 7W higher than the competition, (1) it wouldn't be suited for tablets and soon phones, and (2) the battery life would be insanely short.
Please, learn what "fact" means. Let's quote a reliable source, AnandTech:The fact remains, Kabini is using significantly less power at idle and practically even on load while outperforming bay trail. The 5350 has a 25W TDP, the j1900 has a 10W TDP.
The single threaded performance numbers are just barely ahead of AMD's Jaguar based Kabini SoC. The big difference however is power. I had Intel measure SoC power at the board level while running a single threaded Cinebench 11.5 run on the Atom Z3770 and saw a range of 800mW - 1.2W. AMD on the other hand lists the A4-5000's SoC/APU idle power as 770mW. I don't have equivalent data for AMD, but with the A4-5000 idling at 770mW, it's safe to say that SoC level power consumption is lower on Bay Trail.
Seems out of all these claims, the only person to post a real link is Abwx for the computerbase review. http://www.computerbase.de/2014-04/amd-athlon-5350-kabini-sockel-fs1b-test/3/
LC-Power LC75ITX 75 Watt
The J1800 and J1900 is not the same SoC or the same platform as BayTrail-T Z3770. And yes they may have higher Idle power consumption than the competition.
The chip itself is the same, and that's what we're comparing, right?
His definitely seems more factual than what you posted. Its ironic to try calling someone out on their facts then post another person's conjecture as fact... This is what we get with a flamebait thread like this one.
1. Kabini uses less power at idle.The fact remains, Kabini is using significantly less power at idle and practically even on load while outperforming bay trail. The 5350 has a 25W TDP, the j1900 has a 10W TDP.
Assuming they didn't screw up testing it looks like CERTAIN SKU's of Baytrail do in fact use more power than Kabini. I don't see why that is so hard to believe or admit when it is true- as it appears it is.
However, this doesn't necessarily prove that J1900 uses more than 10 watts- in fact it looks like its close to, or a little over 10W... so quit splitting hairs on that one.
The long and short of it is that Global Foundry's version of desktop Kabini is surprisingly efficient and desktop Baytrail is less efficient than a lot of people assumed. Either way you guys are arguing over a couple watts- I think its time for everyone to sing Kumbaya.
