Don Karnage
Don, I think his point was that IB-E would have a larger die thus better heat dissipation. The issue with Ivy isn't the voltage but rather that it can't dissipate the heat with that added voltage. A larger die could potentially alleviate some of those issues and we may see some higher clocks.
We saw the same with SB vs SB-E where the larger SB-E chips would idle and load at lower temperatures given the other conditions are equal. It's different this time around --as you've already mentioned the prime operating voltage with that chart -- so it remains to be seen how much or if a larger die would benefit.
I'm actually looking very forward to IBE's chip design. I have a feeling Intel is going to spread out the cores to allow for more heat dissipation.
I'll probably be going back to X79 because of it
