Question Integrated and Dedicated GPU - Problems
vcore
10
I have two builds with identical specs the only difference are the gpu and ram. They are both stock.
Build 1:
-12900K
- Asus Rog Strix Z690-F Motherboard
- T Force Delta DDR5
- Samsung 980 Pro
- Corsair HX1000W Multi Rail PSU
- Asus Rog Strix OC RTX 3070 ti
Build 2:
-12900K
-Asus Rog Strix Z690-F Motherboard
- Kingston Fury Beast DDR5
- Samsung 980 Pro
- EVGA FTW3 RTX 3080 ti
Build 2 is working fine with the EVGA GPU.
The problem with Build 1 is that I am experiencing graphic issues like textures look like they move when I move also rendering slow until I get close, some shadows and lighting are flickering.
So I tried moving my Asus GPU and NVME into Build 2 and the same problem occurred.
I then tried using the iGPU alone on Build 1 and was surprised I still had the same problem occur.
What can this issue be? So weird. Why when moving my Asus GPU and NVME into Build 2 it also experienced this same problem?
I also have tried updating bios and drivers with no improvements. Need to find out what is causing this problem if its a hardware issue I need to return it that item asap.
Reactions: Leeea
tamz_msc
3,865
3,730
Is your memory running the XMP profile? Is it stable? Also, are you sure that the Asus GPU is working properly?
vcore
10
I was running it stock before with no XMP. Same issue. Running XMP now and still same issue. I am not sure if my GPU is the issue or not. Because when I try just use the Integrated GPU instead the problem still happens.
I really don't know what it is. I have isolated most things and still baffled and what it could be. The last thing now is power supply, but if it's not. Then I really don't know what is causing the issues?
Leeea
3,799
5,567
-nods-
-nods-
I would suggest clearing your Direct X shader cache.
