But how does it affect you? Answer: it doesnt. You look at the benchmarks, you decide. It's not a low method, it's marketing. So what has AMD done that requires forgiveness?As I pointed out above - they really first HAVE to get to 2.6 GHz (or however much they end up with). And if they DO manage 2.6 GHz, they should be OK without the PR-rating, as any new microarchitechture should really be quite happily boosting up those first few steps on the MHz ladder quite quickly.
But ah well - that is just me. I dislike PR-rating and haven't "forgiven" AMD for it. Find it quite saddening that they had to resort to such low methods (again) ... had hoped they'd have learned better. Ah well.
I see, so a 2000+ Palomino runs at 1667MHz a 2100+ Palomino runs at 1733MHz and a 2200+ Thoroughbred runs at 1800MHz. The added "couple of hundred points" are... where, exactly?They've canned them in the end, as they agreed that it seemed deceitful and confused customers. It's also not as if they're being consistent about it (so - a Thoroughbred core just adds several hundred points for no good reason against Palomino?).
So A Willamette 1.6 being trounced by a PIII 1Ghz and indeed a Willamette 1.8 by a Palomino 1.2 (Ghz) was consistent? The PR system is far from perfect, but at least you can safely say that an XP2000 is roughly equivalent to a P4 2GHz. It's not entirely consistent but it gives AMD a chance in the retail market.At least with "just MHz" you have more consitency and don't advertise beyond that. I've yet to really understand how exactly there is consitency in the PR-rating ... I've failed to see it.
So would you take a Wilamette 2GHz over a Palomino 1.6GHz? The clock speed is 25% higher so it must be betterAnd the "It's not about MHz" is absolute nonesense, as anyone can figure out.
Nope, important when comparing two CPUs of identical clock speedHey guys, if you all think IPC is so much more important than clock speed
Said by...?and the PR system is completely legit
Very true. AMD cannot claim that it is the same as a P4 2GHz because it would result in legal action. And with XP vs P4, some applications favour one or the other, so it's hard to draw a direct comparison.then you know that the offical line from AMD is that the PR rating indicates how fast a Thunderbird would have to be to perform at the same level as the same Palomino. So a PR 2000+ means the Palamino 2000+ performs the same as a Thunderbird 2GHz.
Roughly so, in certain applications, under certain conditions.Thats funny, because we all know that in reality the 2000+ performs about on par with a P4 2GHz.
So the Palomino PR is "On a Par" with the T-Bird MHz and is also "Rougly the same" as the P4 MHz and we can draw definitive conclusions from this? It's marketing. It's advertising. It's not an exact science. To call it fraudulent on the basis of two different imprecise comparisons is pointless. Why do you even care - IT DOESN'T AFFECT YOU!Obviously that means that the P4 and the Thunderbird have the same IPC. Basic logic here people, logic that backfires in AMD's face, and proves the PR system to be completely fraudulent, since we know the Tbird has a higher ICP than the P4.
It's all very well saying we need an industry-wide standard for performance but as dexvx says, different applications favour different CPUs so an entirely objective approach is almost impossible. If you compare the clock speeds of the palominos with the P4s, the XP performs far better at a given clock speed. Comparing the PR rating with the P4s clock-speed gives a much better indication of relative performance. It's not as if there's no parity there. AMD could happily have made the 2200+ into the 2500+ to compete with intels high end processors but they didnt.If its completely imprecise then how is it not fraudulent? Anyway, It's not a matter of directly affecting anyone, espicially anyone on this forum, but it is a matter of principle. You seem to think that it's "unfair" to AMD that Intel's chips scale higher in MHz, and I can't understand that sentiment. If they feel like they need to show people that their chip is simply engineered differently, then they should at least have used an industry standard, industry approved benchmark or naming scheme. I don't have a problem with the idea of a PR system if thats the way it's gonna be, but AMD's system is biased, misleading, and barely holding on to any connection to facts.
But the man on the street doesnt care about the contents, he cares about the speed. If he buys a 3400+ system that runs at about the same speed as the man-next-door's 3.4GHz P4 he's perfectly happy.All I know is, if i was Joe Consumer, and bought a 3400+ system only later to find out it was running at 2GHz, I would be pretty upset and confused, no matter how well the system performed.
Ah, but everyone knows that the stereo system wattage is meaningless.Yea, most consumers are stupid. But PR rating, IMO, is messed up. Its kind of like wattage ratings on stereo systems.
And that's why any complete objectivity is impossible. I think the PR ratings give AMD a chance of being decent competition for Intel in the retail market and that has to be a good thing.Right now there are a lot more factors than Mhz for cpu performance. Frankly I think my 2.4 Ghz Pentium4 northwood with PC1200 RDram at 600Mhz FSB should be a pentium4 2700+ because obviously it can beat a 2.4/400 Ghz p4 running PC2100 DDR.
Now if you factor in SSE2, a Pentium4 1.6 Ghz can BEAT an AthlonXP 1.6Ghz (2000+), clock for clock. So much for that PR system. But in some OTHER applications, an AthlonXP 1.6Ghz can beat a 3Ghz Pentium4. There is way too many variables to determine an accurate PR rating, but so far that PR rating is proving to be pretty accurate.
When I mentioned ?what the PR rating may become?, that?s exactly what my concern is. Are they going to start ?stretching? the numbers, oh because Intel is getting better yields?!Now most of us know that so far AMD has been a little bit conservative with their PR system, as long as they keep that up I will have no problem with it. Even though I think it would be a little disheartening to have to name all of my products according to how the competition is performing.
Again, I?ll have to see a review of an alleged AMD 2.6GHz being able to perform like a true 3.4GHz before I believe it. Then again if they can produce a 2.6GHz, then they should market it like a 2.6GHz, I?m sure the price itself will catch peoples attention.
Originally posted by: Piano Man
Found this today. Not bad for a chip running at 2.6 GHz. Maybe AMD will make a comeback and take the performance crown again.
I assumed it was the precedent. But if you know sometime I don't please share?Originally posted by: SexyK
I'm a bit curious where you got the impression that a 2.6GHz Hammer will cost anything less that $500. All indications point to the new Hammers being priced similarly to the highend P4s.
Kramer
Originally posted by: hungrygoose
so many people here that are saying that the pr system sux seem to either forget or not know that AMD never said that the pr system was a comparison to the P4 chips.....that's now what it is derived from.........just b/c amd and intel are the main competitors doesn't mean that amd's comparison system is comparing to the P4.......how is it misleading when you can't go buy a 2ghz thunderbird?.....u can however buy an xp 2000+ which will be equivalent to a 2ghz thunderbird if such an animal existed.....the PR system has nothing to do with intel.....it's not amd's fault that the average consumer looks at it as a AMD vs. Intel comparison.........they clearly stated what it was for as well as why they did it
Originally posted by: sparks
Think of it this way: what if Intel and AMD went in opposite directions in which the AMD chip is the mega pipelined high frequency CPU and the Intel chip is this more efficient design that squeezes more performance per clock cycle. Think of the market position AMD would enjoy, not only are our chips faster, they cost less too!!! I would be willing to bet Intel would come out with some sort of marketing term for the performance characteristics of their chip.
In a way I hope PR ratings do succeed because if it doesn't, whats to prevent AMD from redesigning their chips where the main focus is frequency and not true performance. Its perception, but I would rather have a cpu with real performance then perceived performance.
So speaks RandIn the end, I view the Model rating as an unfortunate necessity.... so long as the Model rating remains realistic compared to Intel's highest performance X86 processor at a comparative MHz/Model I will accept it.
Right now, I do view it as completely realistic. If the day comes that AMD markets a Model rating that is NOT on par with Intel's competing solution then I will be among the first to speak against AMD.
The point is that intel are 750+ MHz above AMDs highest-clocked part. The PR ratings are to give the Palominos parity with the P4. Sure intel could name their parts the 2800+ or somesuch, but it'd be pointless since they're already ahead in the MHz stakes. It's a marketing gimmick to give AMD a chance to sell equivalent performance at a lower clockspeed.Thats all fine and good, but the Palamino is just a tweaking of the Thunderbird design, so according to your logic, Intel could say the P4 2.53B is a "2800+" because it would take a 2800MHz Willamette to equal the performance of a 2.53GHz Northwood. Jeeze, if that ever happend i'd hate to see the outrage in here, even thought it's exactly the same thing that AMD is doing.
Originally posted by: HOMIcidaL
I own an athlon system right now, but my next system will definitely be INTEL! I just find the rating scheme that AMD uses a step back into the K6 days. I mean comn, give me the correct Mhz rating instead of 3400+ or some bs.
