I'm tired of OOS
gi0rgi0
1,240
Originally posted by: AntiStatic
i bought the Asus (from a guy on this very board lol) they are a bitch to find for sure. I can say this about it: It's rock stable and overclocks like a dream. My Opteron 148 is running @ 2.9 on stock voltage with no issues at all.
What ram are you using ?
Capt Caveman
34,543
651
Originally posted by: kaishaku72
If it's the XP 4000 Redline 2GB kit with Infineon chips then it's
probably the best choice and should do as well as the OCZ EB.
http://www.mushkin.com/doc/products/memory_detail.asp?ID=273
As far as I remember Mushkin was well known before OCZ so
it may even be better, plus they seem to have a better supply
of the Infineon chips? ie. The modules are actually available.
I opted for the 2nd choice, UCCC modules, G.Skill specifically.
The OCZ with UCCC has a heavy rebate and comes to about
just $20 more than the G.Skill so that is an option for those
unwilling to "risk" the new name G.Skill.
Those two use the same Infineon CE-6 chips. Outside of Crucial, eveyone else use the same chips at particular speed levels.
DDR500 3-3-2 is Infineon CE-6
DDR500 3-4-4 or 3-4-3 is Samsung UCCC
In regards to tighter timings and overclocking, it appears that particular batches from each chip do better than others. The first batches of Infineon CE-6 overclocked like crazy and the latest batches aren't doing as well. But the Samsung UCCC appear to be gettings better. My two cents.
