Originally posted by: DrPizza
Originally posted by: Sphexi
There was an estimate that if all of the households in Canada switched to CFLs, it would save enough electricity to power a city of 100K people for a solid year. If all of North America did it, it could power a city of a million for a year. That's a decent amount of power saved, quite a few power plants that could be shut down.
No idea about street lighting, although there probably aren't nearly as many as there are lights in houses, I'm betting they draw more power, so perhaps the savings would be about the same? Different technology though, so I doubt it applies.
Saving the power demands of a city of a million = quite a few power plants?
While very gradually replacing the high pressure sodium lamps with piles of LED's (as the lamps failed) would save some energy, simply removing a perfectly good high pressure sodium lamp and replacing it with and LED would actually increase the power demands: LED's just don't grow on trees; it takes energy to make them. It'd be like tearing a house down and rebuilding it so you could squeeze in an extra half inch of insulation. (shot in the dark approximation)
Oh, also a consideration: in colder climates, particularly 2 story homes where the majority of lighting used is on the lower floor, the claim that energy is "saved" is exaggerated. The "wasted" energy of an incandescent bulb is heat - heat for your home. The only energy wasted (during the months you're heating your home) is the light that shines through your window to the outside. I probably should point out that in the big picture, this is true in homes that have electric heating. In homes with fossil fuel heating (coal, natural gas, propane, or oil), these fuels can be turned into heat at the home with far more efficiency than they can be converted to electricity at a power plant, and then sent to the home where they ultimately are changed back into heat.
i.e.
fossil fuel -> electricity -> home -> CFL bulb in a house with electric heat when it's cold outside: no energy is saved. The incandescent bulb's heat is not "wasted energy."
fossil fuel -> home -> heat;
small amount of fossil fuel -> electricity -> home -> CFL = saved energy. Not at the household level; the house uses just as much energy; but the inherent inefficiency of conversion of fossil fuels to electricity is where the savings occurs.
And, in my case,
3 tons of coal -> nice bright fire in the coal stove -> keeping my house at 75 to 80 degrees in the main living areas, cooler in the bedrooms for sleeping -> I can enjoy the nice warm glow of the fire and not turn on any lightbulbs in the room with the stove -> at a very small fraction of the cost to heat with any other fuel.
Originally posted by: Whoozyerdaddy
Originally posted by: Heisenberg
I'm pretty sure that high pressure sodium lights are about the most efficient lights there are, even more than CFL and LED.
I didn't think there was anything commercially available that was more efficient than LED.
Originally posted by: Thorny
Wouldn't your argument about wasted heat be totally neutralized by the fact that most people run A/C during the summer months? I would think that removing that heat would cost just as much as it would save, especially given that my gas furnace can create it much more efficiently. I switched to CFL last year and this winter my energy consumption was still considerably lower. Yes my initial expense was high, but it's been less than 6 months and they have paid for themselves several times over.
Yeah, I should have mentioned that. However, during the summer when A/C is in use, there are more daylight hours, hence lights aren't on for as much time.
Low pressure / LPS / SOX
LPS Lamps (Low Pressure Sodium), also known as SOX Lamps (Sodium OXide), consist of an outer vacuum envelope of glass coated with an infrared reflecting layer of indium tin oxide, a semiconductor material that allows the visible light wavelengths out and keeps the infrared (heat) back. It has an inner borosilicate 2 ply glass U shaped tube containing sodium metal and a small amount of neon and argon gas Penning mixture to start the gas discharge, so when the lamp is turned on it emits a dim red/pink light to warm the sodium metal and within a few minutes it turns into the common bright orange/yellow color as the sodium metal vaporizes. These lamps produce a virtually monochromatic light in the 590 nm wavelength. As a result, objects have no color rendering under a LPS light and are seen only by their reflection of the 590 nm light (orange).
LPS lamps are the most efficient electrically powered light source when measured for photopic lighting conditions. ? up to 200 lm/W[1]. As a result they are widely used for outdoor lighting such as street lights and security lighting where color rendition is viewed by many to be less important. LPS lamps are available with power ratings from 10 W up to 180 W, however length increases greatly with wattage creating problems for designers.
LPS lamps are more closely related to fluorescent than High Intensity Discharge lamps, since they have a low?pressure, low?intensity discharge source and a linear lamp shape. Also like fluorecents they do not exhibit a bright arc as do other HID lamps, rather they emit a softer luminous glow, resulting in less glare.
Another unique property of LPS lamps is that, unlike other lamp types, they do not decline in lumen output with age. As an example, Mercury Vapor HID lamps become very dull towards the end of their lives, to the point of being ineffective, whilst still drawing their full rated load of electricity. LPS lamps, however, do increase energy usage towards their end of life, which is usually rated around 18,000 hours for modern lamps.
Originally posted by: Pepsi90919
my region started moving to LEDs early on in traffic signals. now they have started moving back to brilliant incandescent lights, because the LEDs they were using were breaking and cracking.
Originally posted by: Mark R
Typical efficiencies:
Tungsten incandescent (vacuum fill striplight) - 6 lm/W
Tungsten incandescent (standard bulb) - 12 lm/W
Tungsten incandescent (mains voltage halogen striplight) - 18 lm/W
Tungsten incandescent (low voltage halogen capsule) - 20 lm/W
Compact fluorescent (standard color quality, conventional start) - 50 lm/W
Compact fluorescent (standard color quality, electronic start) - 55 lm/W
Linear fluorescent (enhanced color quality) - 95 lm/W
Linear fluorescent (premium color quality) - 75 lm/W
Metal halide (Daylight color) - 85 lm/W
High pressure sodium - 140 lm/W
Low pressure sodium - 165 lm/W
LED (white, current technology) - 60 lm/W
LED (white, prototype) - 90-100 lm/W
LED (green, current technology) - 50 lm/W (but avoids need to use light blocking colored filters)
Originally posted by: MrPickins
All the street lights I've seen for the past 10 years or so have been low pressure sodium...
Much more efficient than LED's or CF.
Originally posted by: MS Dawn
Most streetlights are HPS not LPS.
500 l/w is not out of the question with LED's! :shocked: They will become a serious candidate for stage lighting. 😀
i.e.
And, in my case,
Most streetlights are HPS not LPS. LPS can be easily distinguished by its deep yellow-orange glow which looks just like sodium burning on water. They are can be found in tunnels and parking garages. The biggest complaint from people is they have a hard time finding their car because of the zero CRI of these lamps! HPS have a much whiter output with a golden glow and measurable CRI. Potheads use them to raise their goods too. 😉
Currently LPS have the highest efficacy but LED technology will surpass it - and have excellent CRI as well. 500 l/w is not out of the question with LED's! :shocked: They will become a serious candidate for stage lighting. 😀
Um, no? When we used electric heat at home, the winter electric bills would sometimes be $400 for just one month, and that was for heating upstairs and maybe one room in the basement. It was less than half of that in the summer for air conditioning the entire house. It's not a big house, mind you, maybe 1000 sq ft per floor. It's a one story house with a basement.Originally posted by: totalcommand
Actually, it would be more than neutralized. It takes SIGNIFICANTLY more energy to cool a place than to heat it (simple thermo). So the wasted heat by the incandescent would require a larger amount of energy for the AC to cool down.
Further, some of the energy the incandescent uses is converted to visible light. It is not the best heat generating source, which is why we have electric furnaces. So the tradition light bulb is not a direct 1:1 substitute for heating in our homes in the winter. This is probably why you saved money during the winter.
