bobdole369
- Dec 15, 2004
- 4,504
- 2
- 0
The appropriate sized set to buy is the one that fits both the intended viewing distance from the device, and the resolution of the content to be watched. Bigger isn't always better.
And any prices saved by going DLP would be offset by the cost of replacing the bulb every 2-3yrs.
I also somehow doubt that the mitsu 65" DLP would have better blacks and contrast levels than a 52" Sony Bravia.
DLP? I thought people stopped buying that 2 years ago...
To the people who think DLP is going obselete or useless .....
Black Levels / Contrast is quite good on a CRT DLP. Much better than LCDS, and noticably better than Plasma.
A 65inch DLP costs less than most 50 inch plasma's/LCDs.
DLP does have some shortcomings, but it's got some benefits too.
LCDs and Plasmas offer better brightness usually, but if it's in a light controlled environment, a DLP might have bett
As long as you have the room for it, I'd always go with the 65". But make sure it will fit first, they always look smaller in the store. One of my friends has a projection TV with an 8' screen, movies are awesome.
You mean projector?
You mean projector?
Yes, I meant projector. It's mounted on the back wall of his living room, and from that distance fills the 8' screen he bought. With his 7.1 surround sound, it's almost like going to the theater. (minus the annoying people) It is a tv as well, but SD cable will make your eyes bleed, so he only uses it for DVDs. He has a 60" that he uses for watching cable. The 8' screen is mounted on the ceiling just in front of the smaller tv, so when it comes down you can't see the smaller screen.
You should tell him to hook up OTA HD
I don't think it an HD projector. He's had it for a while now, and I'm pretty sure he got it before everything went HD. It still looks really good with DVDs though. It's a Sony, but I can't remember the model.
Define a while ago
4-5 years. He's been married for 3 years now, and he got it before that.
If you have room for a 60" then you have room for a 65". And $200 is negligible if you're getting a screen of those sizes.
Bulbs in DLPs last a bit longer than the 2-3 years that people in ATOT always quote. That might be a decent estimate if you don't properly calibrate the TV and use the default settings which are quite bright. That would certainly reduce a bulb's life. I calibrated both of my DLPs with the AVIA DVD. My 42" is still doing fine after five years and my 61" is at three years with no bulb issues.
With all due respect, why in the world would anyone buy DLP anymore? What advantage does it offer? And the bulb issue...
Sears has the Panny 54" 1080p/600Hz plasma right now for $1099. It's an excellent deal on possibly the best bang for the buck TV on the market. It trumps the DLP all the way around.
You're not comparing apples to apples though. How much is the 58" (closest to 60" I'm pretty sure), or the 65" ? DLP still trumps all if you are looking for the best bang for the buck.
