If Plasma is superior to LCD, and cheaper, why is it not selling well?
Anubis
78,712
427
tbqhwy.com
um... wow dude... I don't even know what to say. youre being delusional
no hes spot on, weight, thickness and power consumption are non factors
the only place LCD wins over Plasma is really small < 40" and very large > 65" in the consumer market
the 85inch Panny Plasma (VX200) is a sight to behold and yes ive seen one. its only issue is that it costs like $200000
and yes darksword prices come down, my point being they wont for a long time as yeild on OLED TV is still absolute crap.
jaqie
2,471
jeez my own personal opinion of what constitutes really small and very large screens is way off of what the contemporary view seems to be...
to me anything over 32 inches seems very large and anything under 19 inches seems very small for monitors AND tvs alike.
maybe my age is showing? I dunno.
Eug
23,825
1,396
That's not true. Current plasmas are a lot thinner and lighter than before, and use way less power than before, so that they're comparable to LCDs of years ago. However, during that same period, LCD technology has also progressed, so that LCD/LED is even thinner and lighter, and lower power than plasma on average.
For size, it may not matter that much, unless you're wall mounting it. However, power utilization differences can still add up, to tens of $ per year. It's not going to break you, but over the life of the TV that may be several hundred dollars worth of electricity if you watch several hours of TV every day.
Stuka87
6,240
2,559
And Samsung led the charge. They were soooooo good, people now think there are new LED TV's which are better than the old LCD's and plasmas. :rolleyes:
New LED TV's are better than old LCD TV's, period. They are thinner, lighter, use less power, and wont yellow after a year of use. As for having better image than old Plasmas, that would need to be compared on a case by case basis. But many of the IPS based LED TV's have very good blacks, maybe not as good as a Plasma, but the majority of people could not tell the difference. Kind of like how the majority of people could not tell the difference between $100 dollar headphones and $500 headphones.
To the guy that said "you watch TV from the front", that is the stupidest comment here. I probably spend a good 25% of my TV watching while in the kitchen looking at my TV from an angle. View angle is a BIG deal for many people.
JAG87
3,921
All this drivel and nobody still pointed out why LCD/LED wins over plasma... incredible.
90% of people will buy their TVs in a store (i.e. Best Buy, Costco, whatever), will not do research ahead of time, and will judge the TV solely on the picture they see, and the price tag. In the store, an LCD/LED will smack a plasma in every which way you can imagine, because the store will show you torch-mode panels sitting under bright lights. The plasma doesn't stand a chance.
The only people who buy plasma are those who go into a proper AV store, where the TVs are setup in dark theaters, and they see that plasma is far superior, or those who do research online, know what they want, and more often then not buy it online too.
These people constitute like 5-10% of the market. The other 90% buys LED.
End of story.
JackBurton
15,993
14
It's not an LED TV!! Do you refer to the "old LCD" as a CCFL TV? It's an LCD with an LED light source, but it's still an LCD. Period. Christ, that is so annoying.
And no, all LED based LCD's are not better than a traditional CCFL LCD across the board. The majority of the LED LCD's are edge lit, and they're junk. If you are hell bent on purchasing an LED based LCD, a full array LED backlit LCD is the only way to go. That is the only type of LCD that can come anywhere close to competing with a plasma's black level. And the 2 currently on the market are Sony's HX950 and Sharp's Elite X5FD, both are priced MUCH higher than a comping plasma.
Secondly, motion is still an issue with even the best LCD's. Even the average Joe Blow can see the difference. Some don't mind it, others hate it. Personally, I can't stand it (I'm somewhat of a purist). My wife is no technical guru when it comes to TV's (hell, she couldn't tell you the difference between an LCD or a plasma), but when she sees a movie playing on an LCD in the store, she immediately makes the comment, "hey, it's doing that weird thing." She doesn't know the technical term for it (frame interpolation), but she knows it doesn't look like it should and hates it. Sure you can turn down the settings to reduce the effect, but then you just unmask the LCD's true issue with motion.
These stupid reasons for buying an LCD (weight, power savings, thinness, apps) are just marketing gimmicks to get people to look past what should be the most important aspect of an HDTV, picture quality and performance. That's where most fail, and why LCD manufactures have to use these stupid marketing gimmicks to get the general public to buy in. And apparently it's a GREAT strategy, because it's working.
And just a side note, one of the best LCD's ever produced was Sony's XBR8, which was a fully backlit RGB LED set. Fantastic LCD. Too bad it was just too expensive to keep producing. Oh, and it was one of the thickest flat panels I've ever seen at almost half a foot deep.
Throckmorton
16,829
End of story.
Torch mode? I usually turn my monitors and TVs as bright as they will go to approximate reality. The only place a dim screen is acceptable is in a dark "home theatre" room.
bigboxes
40,380
12,240
The only thing stupider is taking things out of context. The only thing I meant about not watching "tv from the side" is directed at those that buy their televisions based on thickness of the screen (or thinness). But if you want to go that way, plasmas have much better viewing angles than LCD as well. Argue with that and you further prove your ignorance.
jaqie
2,471
some people value different things than you, bigboxes.
including me.
I can't lift much anymore and like to rearrange a lot, so weight is a big issue to me.
A5
4,902
:rolleyes:
So somehow it becomes an unavoidable law of physics that they chose to develop flash technology based SSDs instead of MRAM or SRAM or other unlimited write based ones, and such? You really need to get out more.
As for the other person saying it will outlast the backlight in LCDs... um, the backlight in current ones are LEDs, and they have a life based on how hard they are driven - they could make LEDs that last literally thousands of years with quite bright output, but they don't. Another perfect example of what I mean. Also, the backlight is replacable in the older ones, I have done so myself more than once. That is most definitely not the same thing as the base device having a set limited life to it.
They didn't use MRAM or SRAM because it would require either a massive, multi-billion dollar fab conversion (MRAM) or just plain cost more (SRAM). NAND SSDs were developed because they are cheap to make using equipment these companies already have and are still a huge improvement over what is already out there.
The best tech doesn't always win.
JAG87
3,921
That's exactly why you and the mass likes LCDs better. A properly calibrated display should put out between 80-120 cd/m2 in a dark room, and 120-160 cd/m2 in a bright room.
LCDs in the store are set up with max brightness and put out 300-400 cd/m2, completely skewing the color temperature, black level, contrast, and gamma. Of course, they look much brighter and more colorful then any plasma, which can barely approach 200 cd/m2 with the brightness turned all the way up, even before discounting any glare . The dumb consumer likes this, because in the bright store everything just pops more on the LCD.
dagamer34
2,591
Trying to convince the market to rate anything based on it's merits instead of marketing is... well... a fools game. Sad, but true. Thing is, you don't need everyone else in the world to have properly calibrated and color corrected TVs, just you. Let the rest of the world buy what looks good to them. It doesn't hurt you! ;)
ImpulsE69
14,946
1,077
Amen.
History is full of examples where the better version didn't win, and life went on.
ImpulsE69
14,946
1,077
Sounds like plasmas need to step up their game then. Call me dumb all you want, but if people prefer brighter and over saturated, and pop then "they" are right. That's equates to a shortcoming on the plasma side, not stupidity on the consumer side. It's called preference. Just because someone says "it should be like this" doesn't mean it's to everyones taste. That's why they put those picture changing options on the the sets, otherwise, they could just leave them completely off and say "this is how it looks, deal with it".
JackBurton
15,993
14
Well, it actually does. It's a big reason why I will never have my ECC (Extreme Contrast Concept) Pioneer display. :mad: We were sooooooo close. :(
Zargon
12,218
ok, you are dumb, if you think that a TV displaying PROPER COLORS is wrong because marketing people convinced the slackjawed masses that its how is should be, just to cover the flaws of their products
hey I have some asbestos and uranium clothes to sell you, right after my marketing guys get a catchy slogan and I pay some other morons to tell you they are awesome! :whiste:
(yeah I went with a strawman, it seemed appropriate)
ImpulsE69
14,946
1,077
How does marketing impact my visual preference? I looked for nearly 6 months at many more TV's than I could care to count. I've seen calibrated plasmas. The only thing "better' about them were black levels. It still comes down to preference. No one told me "how" it should look except the people yelling about how plasma is better....
I'm not saying you are wrong about plasma, I'm saying that it's your opinion, and everyones opinion is going to vary. Just like people prefer different amounts of treble, mid, and bass in music. It doesn't matter that it was "intended" to be heard in a specific way. It matters what the person listening likes. It is no different for visuals. For people who aren't videophiles, it matters even less.
I guess to further the conversation I'll stand by my statement earlier. If it truly is marketing and dumb consumers that don't know any better, and prices are comparable, then plasma makers obviously need to change their strategy, either with better marketing or a change of tech to accommodate those people falling prey to the "lies" of the LCD sellers. Don't take my statements as a champion for LCD's because I fought it tooth and nail (as I did Plasma). Overall the tech we call HD these days still seems damned inferior overall, but at least it seems to be getting somewhat better(or my eyes are adjusting :p )
jaqie
2,471
Yet again I find myself completely agreeing with impulese69.
You are spot on IMO, and I think I like yah. :D
poofyhairguy
14,612
318
Did you look at these calibrated plasmas long enough that you got to see some fast motion on them? Because if not you missed the best part.
Once you get used to plasma motion, even 240hz LEDs just look terrible.
I mean, people are just used to a thrown football being the blurry thing in the middle of the screen. The day you actually can see the ball clearly all the way into the receiver's hands is the day you really know the point of plasma.
Eug
23,825
1,396
I disagree. I prefer plasma in general, but quite honestly I'd be just fine with an LED-backlit LCD.
The latest batches of LCDs are pretty good. They may not be the best in everything but they are by no means bad. Furthermore, just the fact that you get matte on the LCD is a humungous advantage for LCD. The glare on my plasma is a continual irritant. It's not a deal killer for me obviously but I suspect it is for a lot of people.
