Originally posted by: irishScott
Originally posted by: archcommus
Wow, here come the misinformed FF zealots again. Some things will never change. At least there are a few saints in here who use FF but admit it's mostly due to their habits and that IE is actually just fine.
For all of you who don't know sh!t:
- IE7 does have extenions, they're just call add-ons instead
- With one single add-on IE7 CAN block flash ads and normal ads, AND support retrieving recently closed tabs
- IE7 on default without add-ons can save/restore a session
- Tabs can be turned OFF, the menu bar can be turned back ON, and using a single add-on the menu bar can even be moved back to the familiar IE6 position
- Add-ons can be had to add script support, mouse gestures, spell checking, and inline searching
- For most users it's exremely stable and loads faster than other browsers. Even if this IS because things are pre-loaded in the OS, who the fvck cares? It still benefits me!
Do I need to continue? Sheesh.
FF has thousands of extensions, and if you really want to add something that's not there yet, or modify something so that it works better; with a little programming expertise, you probably can. IE will never be able to compete with OSS for extensions.
So Can FF
FF also stores sessions by default.
Disabling Tabs and bringing back IE6 is even worse, and is irrelevant.
And FF has a spellchecker. Beat that.
