FelixDeCat
- Aug 4, 2000
- 31,012
- 2,682
- 126
guess whats the first result for "Hexikopter" search on google is?
No, he's correct. I've seen the quadrotors before, but the hexagonal arrangement seems to be much more aesthetically pleasing. They also have an oktokopter, and again, the hexikopter looks cleaner.
I personally think the ideal thing is to make a small scale looking deck with a clear window & stick some hamsters inside. Equip it with a small loud speaker. "Earth creatures, we have arrived from..." Ehhh, maybe the hamsters would be too much of a giveaway. But, I guarantee you that if I had one, UFO sightings in my area would skyrocket.
I'm not saying the hexikopter isn't awesome, because it is, but there is very little difference in control and zero difference in (a general six-rotor platform) capability between it and a quadrotor.
A hexikopter could (in theory, with the right programming) survive an engine failure without losing total control (shut down the opposite engine also and then it'd be similar to a quadrotor, though I don't know if the orientation of the props (clockwise / counterclockwise spin) would be the same), though, while a quadrotor would need some really fancypants programming to avoid crashing if it lost an engine, and it would lose the ability to perform some actions.
I didn't watch any for the Hexikopter, but for the Oktokopter, they have test flights where they knocked out 1 to 4 of the engines & it stayed in flight just fine. Excellent programming.
It actually should almost be a function of the hardware and require very little software to take an engine loss in stride on a hexi or octi or whatever-i copter.
How would you build a large scale version, do you think? use large electric motors with maybe a turbine powered generator driving them, multiple fuel drinking engines, or one engine driving all rotors, but with the collective on each rotor being independent?
That last one seems like the easiest and most weight effective, but an engine failure will still mean autorotate or death.
Come to think of it I guess there isn't a huge point to a large quad+ copter. Seems they're destined for more small UAV work.
And Pizza, don't tempt me. I don't have the time to build one of these things, but you can bet if I did it would be loaded with bright LEDS and be seen flying over Rochester![]()
Anyone find a price on these or the four rotor versions that can carry a camera? A fully assembled one, not a kit, for those who are too shiftless/lazy/uncoordinated to build their own?
Absolutely badass. It would be horrible for stealth operations though - notice how loud it is?
