funboy6942
- Nov 13, 2001
- 15,308
- 393
- 126
Originally posted by: goku
i took my car to a mechanic yesterday for a tune up, he said I needed a tranny flush, oil change, blinker fluid change, headlight adjustment, and differential fluid change, which I was fine with. All going to cost around $200. Though I started to get weary when he also said that my radiator is going to spring a leak and that it needs to be replaced asap, which is going to cost around $1000. Also he may have to change the head gasket which is also going to be lots of money as there is oil in the coolant? He mentioned something about os2 sensors? I dunno, but he said that they need to replaced since the car has 80,000 miles on it.
This is going to cost me around $1423 according to him, that is if he DOESN't change the head gasket which would be an additional $1500+, he says that next time I get an oil change, that I have to change the headgasket. Think I'm getting ripped off? Should I got to another mechanic? what kind of estimate should I expect?
I laughed good parody. Blinker fluid BTW I think was you give away. Would of almost bought it if it wasnt for that.
