if I got a Prius I would never be able to get my man card back.
I had a lot of Civics before this
Uhhh I think this is a pretty poor recommendation. High ethanol content gasoline has less energy by volume so you'd need more volume for similar power and your mileage would actually probably go down (although high ethanol content gasoline is less expensive). In addition to this, the seals and gaskets in the fuel pump, fuel lines, etc may not be suitable for high ethanol content, and may fail prematurely. Yes, pure ethanol has a higher octane rating than gasoline, something like 105 for E85, but unless you want to modify your entire fuel delivery system, then it's not suitable for most people.This topic came up on a radio talk show the other day.
Just use a regular gas that is of high(er) ethanol content (ie, a high ethanol content regular blend gasoline fuel).
WHere do you guys live where premium is only 20 cents more than regular? Every gas station in my area sells midgrade for 20-30 cents more than 87 and a further 20-30 cents more than that to step up to premium. Percentage wise that is a huge difference over 87.
costco and the cheaper gas stations have a 20 cent differential between 87 and 91, non-cheap have a 30 cent differential. At least that's the trend I've noticed in LA since the late 90's.
a 40-60 cent differential between 87 and 91 is wtf?
Define "typical". Seems like California is the odd man out as from what I've seen the 20 cents per grade is normal.
Also, I must say that's yet another reason I have no interest in living in CA. That's $1/gal more than out here. LOL.
For 2017, the national average of gas has been:
Regular: $2.415
Midgrade: $2.682
Premium: $2.917
Delta:
Regular->Midgrade: $0.267
Midgrade->Premium: $0.235
Regular->Midgrade: $0.502
Source:
https://www.eia.gov/dnav/pet/pet_pri_gnd_dcus_nus_a.htm
My car requires premium fuel and gets about 12 MPG. I haven't had to put gas in it for over two months. Saves me a bit of money that way.
Is it written in the dash to only use premium? If it doesn't, I would just put regular.
