I keep getting ticks in my hair!
WHAMPOM
7,628
183
Deer ticks are dark colored and the size of a match head, bear ticks are the size of a pin head. Lice are gray, look like coarse salt. Live in your hair. Fleas are brown and jump. They bite your legs and make you itch. Usually live in your rug or where your pet sleeps.
From a local news bulletin: A tick takes at least 36 hours to infect you with lymes disease, do a daily body check for ticks.
TXHokie
2,558
176
I found a tick on me the one time in my life when I was dating this girl with a dog. Ex-girlfriend pronto...
KillerCharlie
3,691
68
Originally posted by: moshquerade
Originally posted by: Philippine Mango
Are you sure it's a tick and not LICE!?
it sounds like lice.
OP get checked by a nurse or doctor. lice will live on your bedding, furniture, comb, etc.
you need to get off your butt and take some action.
I've only found one damn bug in my hair, I thought lice came in a big pack?
only one? you are changing your story.
Yeah, I shower and wash my hair daily. But, every couple weeks for the past two months, I go to scratch my head, and I grab a fvcking tick. From there, I freak out, search my hair 50 times for ticks, shower multiple times, and still find nothing. Repeat every two weeks. WHERE ARE THE DAMN THINGS COMING FROM?!
I'm pretty sure he means he only finds one at a time.
SLCentral
3,542
Originally posted by: Jeff7
Ticks
Lice
I'm almost 100% sure it ws a tick. Thank god, I'd rather have a tick then lice.
Originally posted by: JDrake
how long is your hair
Average male length.
Yeah, basically I find one appx. every two weeks for the past couple months. Never found more then one at time, or within two weeks.
WildHorse
5,006
You wouldn't just "grab" a tick. Those things burrow down deep into your skin, so their evil head is subcutaneous. ANd you don't feel their presence, because they numb the area of flesh they chomp into.
If you try to pull a tick off, it's body pops off leaving the evil head & jaws still clamped under there. It takes some work to detach a tick, such as hot match head & pull with tweezers using a twisting motion. It's all in the wrist.
You wouldn't remove a tick just with fingernails, except if you got lucky & happened to catch it before it ate its way into your body.
So you probably have lice, not ticks.
Just as a precaution, read something about Lime disease to help become aware what to notice in yourself.
SLCentral
3,542
That scares the sh!t of me. Eek. I thought ticks crawl around before actually digging in?
EDIT: http://www.cdc.gov/ncidod/dpd/parasites/lice/headlice_penny.jpg
What I found the other day looked nothing like this. It was def. a little bigger, and looked pretty much exactly like pictures of ticks I found online. Then again, this was a few days ago.
WildHorse
5,006
< words cut here >
They're really fast. Triple Crown fast.
Ticks could run from your boot to your scalp in maybe less than 60 seconds. They don't go in a beeline though.
What freaks me out is, I'll be in the middle of 3 people on the trail. The ones in front & behind me will both get ticks, & I don't. This happened several times. Then at night in my sleeping bag I lay there worrying that maybe it's on me hiding, but I can't feel it (you can't feel them).
Luckily none of us caught Lime disease yet, although in the last 35 years Lime disease has spread from genesis on Plum Island all the way to California now, and up into western Canada.
Jeff7
41,596
20
Depends. Some of the things are awfully indecisive about where to nestle in, so they crawl around awhile.
Must be some crazy ticks out your way. Ticks out here are slow and stupid. Still quite prolific though.
WildHorse
5,006
skace
14,488
7
You can often catch ticks before they burrow deep. That isn't very surprising. And you can usually feel them to some extent. If they bite you they can make you itch a little. 90% of the time you detect them simply by scratching an itch.
The fact that you keep getting them is rather nasty though. I used to hike all over and got very few ticks in my entire childhood. Got one on my ass though, that wasn't pleasant.
Dec 27, 2001
11,272
I'll never hear the word "tick" again without thinking of that episode of House.
But, ya, you're not supposed to pull them off as I've heard their head becomes dislodged inside you and could, in the worst case scenario, enter your freaking blood stream. You need a glob of vasoline (I'm sure you've got a few cases handy) and put a glob on it until it lets go. The one time I had one, the doctor killed it using a match and had to jab the head out with a needle.
MrColin
2,403
They may be coming from/breeding on rodents that live in your house. Kill the rodents, bomb for bugs, in that order.
Insane3D
19,446
:roll:
Do not twist the tick or turn the tweezers as you pull out the tick. Pull out straight with a slow, steady motion. Twisting may force more organisms into your body, and may result in the head or more of the mouthparts being left in your body.
Do not apply any substances to the tick before removing it - no alcohol or nail polish, no petroleum jelly or other ointments, and do not try to burn it out or otherwise convince to let go of you. It won't let go. It will just happily keep on sucking your blood and pumping pathogens into you.
http://www.anapsid.org/lyme/removingticks.html
Also, it's very unlikely you will have the head get stuck in, and if you do, there just a slight chance of infection, and no, the head itself will not "enter the bloodstream".
