I FSCKING HATE low flow toilets...
nakedfrog
62,919
19,148
Originally posted by: TStep
I would suggest adding more Pabst Blue Ribbon to your daily dietary intake, but I'm not an advocate of underage drinking.
I suggest at least six per day. Not that I condone it either.
Chiropteran
9,811
110
Originally posted by: Marlin1975
Originally posted by: Howard
Contrary to popular belief, there are low-flow toilets that'll flush most anything in one pass.
I doubt it.
Did you read my link?
Correct. There are good toliets and bad ones, just like everything else made.
I went back and read it. Interesting, but no real proof of anything. What I need is a toilet bowl superstore with a "try out" bathroom. Of course I would have to visit the store many times over the course of a few months to try out each of the products.
Howard
47,982
11
I doubt it.
By that reasoning, any online review has no real proof.
mb
10,233
I didn't read the rant, but two things:
1) R
2) Hold down the handle while flushing for as long as you need to and you won't have any problems
Chiropteran
9,811
110
By that reasoning, any online review has no real proof.[/quote]
No, actually most online reviews do have "proof or anything", they have benchmarks, tests, etc. I didn't see anything like that following your link.
Project86
1,004
It's not just the AMOUNT of water involved, but also the PRESSURE. I've seen old school toilets with tons of water that don't work well, because the water lazily slinks down the hole. I've also seen low flows that keep you alert for fear of losing a limb. So there is more to the equation than just gallons.
Also, it's been said before but less eloquently:
If it's yellow, let it mellow
If it's brown, flush it down.
Howard
47,982
11
Can they not be fabricated?
EDIT: Are you asking for video clips of those toilets flushing large, misshapen turds?
Cooler
3,835
goku you should get a new toilet.
im sure if you set up I need new toilet fund ATOT would help out.
imported_goku
7,613
Originally posted by: FrankyJunior
OP, how old is your toilet?
When low flow toilets first came out they had tons of problems. CUrrent ones work great.
When I bought my house 4+ years ago it had a huge 5 gallon or so flushing toilet. The thing would clog up every other time I used it. So a couple years ago I bought an Elger toilet from Menards. It's a 1.5 gallon low flow toilet. I can load that thing up pretty good before it will clog. It works FAR FAR better than the old one I had even though it uses like 1/3 of the water.
Plus the effect on our water bill was amazing. It dropped $10-$20 or so and there's only two of us living here. Imaging having a whole family and going frmo a 5 to a 1.5. the water svings would be huge.
I'd go check and see how old that toilet it and if it's know to have clogging issues. Then maybe just go buy a better one.
The toilet is from 2003/4.
Chiropteran
9,811
110
No, I don't want to see turd videos. I also don't trust a review that really doesn't have any substance. Perhaps it isn't possible to write a toilet review online that I would trust, it might just be how things are.
Genx87
41,091
513
This is one of the best rants I have seen here.
Low flow == junk
If you want to save on water when you piss, go in the sink.
Shame
2,730
Low flow == junk
Or on an electrical outlet. That'll save ya all sorts of money... :p
DanTMWTMP
15,908
19
LOL. grade A+ rant.
I have similar problems in the past as well. But ya, industrial toilets = WIN. I've always did not understand why public toilets have them, but not homes. Every home should be blessed w/ one of those toilets.
0roo0roo
64,795
84
yea old ones were poorly designed. new ones have dual flush settings and or pressure assisted flush
classy
15,219
You need to buy good low flow toilets, thats the key. I bought a Kohler Memoirs toilet for my half bath and it is great. Its as good if not better than my two other 3 gallon toilets.
Coquito
8,559
You better have washed your hands in between posting here & working to unclog your toilet.
imported_goku
7,613
