I failed at replacing transmission fluid. What is this going to cost me?
Pulsar
5,224
306
I think it's a boss until you machine it into a threaded hole. :D
Nope. Still a boss. A boss is the small protuberence in the casting.
<==== does head & block machining for a living.
JCH13
4,981
66
That was already posted, and I used a smiley, and wrote "I think", and still people are trying to correct me. :biggrin:
On another forum everyone posts sarcasm in purple colored text... it helps when your sarcasm meter is borked, as mine clearly is!
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
It's called a boss. ^_^
Pretty good advice thus far.
If it were me I would want to replace the housing or otherwise repair the damage. Drill/tapping isn't too scary, it helps to use grease on the drill/tap to catch metal chips.
I have had really bad experiences with expanding rubber plugs, but YMMV.
Good luck.
I've had occasional problems with the expanding rubber plugs when plugging something that's under pressure (rotted out freeze plugs on my old lebaron); but they've always worked just fine when there wasn't a lot of pressure.
skyking
22,786
5,941
That's why I think it would be a long term fix. Not only is it not under a lot of pressure, it is not a really "wet" location either. I have the same trans in our honda.
JCH13
4,981
66
I've had rubber plugs rot when in contact with certain oils/fuels. Diesel being the most recent failure. I would want to make REAL sure it was compatible with ATF or whatever transmission oil was being used.
Hmongkeysauce
360
So if I get an expansion plug, should I get it just a tad bigger than the whole?
On another note, I got around calling some shops near me. One owner wanted $2600 for a new transmission installed. He even went as far as telling me to commit some insurance fraud so I wouldn't have to pay a dime. I kind of gave up hope after that one phone call.
sontakke
895
11
Anything which will prevent the leak will work. You are never going to open it again and add fluid from there.
Fritzo
41,920
2,161
You can get a broken bolt extractor kit for $20, or a garage might be able to remove it for you for around $30 or so. Something similar happened to my oil pan bolt once. I was able to tap into it with an extractor bit and then get it out.
LTC8K6
28,520
1,576
The problem is not a broken bolt, but a broken boss on the transmission case that the bolt used to screw in to. Basically, it's a hole in the top of the case that needs to be plugged.
Fritzo
41,920
2,161
Huh. Looked like a bolt to me. If it's not leaking anything, I wouldn't worry about it. If it is leaking, I'd get it to a garage so it can be drained and welded.
You COULD try filling it with epoxy, but without knowing what that hole is for or if it would actually hold, I have no idea if that would work.
JCH13
4,981
66
If you choose to go the epoxy route, I strongly encourage the use of auto-mixing applicators like this:
Life sucks so much less in basically every way when using these.
Squisher
21,204
66
I have to believe there was some imperfection in the casting that allowed you to do this. It seems there are different shades of discoloration where that break is showing that some of the break was there for a while. I think deadken's epoxy fix might be the easiest to try first. It could be welded, but that would likely require dropping the trans.
Late '90's GM trans have these fill ports, but the screw in plugs are plastic. It'd be nice if you can find a plastic plug to replace the one stuck in the broken collar, but you'll have to play attention to the size and thread pitch. With a plastic plug you'll won't need the amount of effort to unscrew them in the future.
evident
12,132
754
and dont ever catch a whiff of it. god it smells gross. i mixed it in my closed garage once and i wanted to puke
LTC8K6
28,520
1,576
The epoxy would enter the transmission. The bolt is not there, and can't be put there. The case itself is broken where the bolt would go.
JCH13
4,981
66
Rather than just pouring epoxy in there, a plug of some sort should be glued in. Or so it would seem...
evident
12,132
754
if you drill out the bolt, wouldnt the fluid help flush the shavings out of the transmission while you are doing it?
bamx2
483
Leave it alone (no drilling or extractor etc). Cover it with a quarter sized piece of metal (cut from aluminum can) glued on with epoxy putty or JB weld (epoxy w/filler). As others have mention, filling the transmission through the dipstic tube will be fine.
PottedMeat
12,363
475
I'm not sure why it's so hard to grasp that there's no bolt there...?
it's just the way the picture was taken
to me it looks like either:
1. bolt sheared off and you're looking at the top
or
2. transmission fluid surface
or
3. some metal baffle or little chamber that goes to the rest of the transmission
Squisher
21,204
66
I was talking about gluing the boss that broke off back on, not filling up the top of his trans with epoxy.
LTC8K6
28,520
1,576
or
or
The part of the trans case that the bolt screws into, has broken. Imagine you are tightening a bolt into a nut, and the nut cracks in half.
It's simple to understand, and hard to fix.
BUTCH1
20,433
1,769
Should be able to drill enough for a tap and extract the plug without drilling completely through the plug. Then replace it with a new one. Hours work tops.
I would agree with this idea but for the chance of metal shavings falling into the tranny, IMO JB weld "stick" version is your friend here, it comes in a plastic tube and you break off a chunk and roll it around in you fingers for a bit, (to mix the 2 parts) then use as needed, since it's not in a liquid form it wont fall into the opening into the tranny, then just fill with the dipstick hole.
