Originally posted by: Special K
Originally posted by: OneOfTheseDays
What's your diet like?
If your worried about having too much flab then up the cardio big time. If you start doing serious cardio with a very good diet you will lose those extra lbs on the sides.
This is terrible advice if you are trying to preserve muscle while losing fat. Cardio is catabolic - a lot of cardio will eat up your muscle.
The best way to lose fat while retaining muscle is to eat slightly below maintenance and keep the weights heavy. This will burn fat while encouraging your body to hold onto the muscle.
If you must do cardio, do a few short-duration, high-intensity sessions per week (HIIT is commonly used).
Umm... rowing anyone? Seriously, just do an hour of Erging (rowing) with the dampner set at 10. Great cardio, and if you pull hard enough I seriously doubt you will lose ANY muscle. You'll actually gain muscle if you stick with it. Worked for me, but I don't lift weights, so nothing to compare it too.
However, I did go from 165 and out of shape to 172 and in great shape over the course of a month or so (rowing 1 hour, damper set to ten, 5 days a week).
Also, as the guide mentions, go in spurts. Do 3-5 minutes of easy-moderate rowing to get the heart going, then 2-3 minutes of hardcore "feel the burn" rowing, at least to start off with until you find a routine that works. I don't know how strong you are in the muscle groups below, but it will definitely make you hurt in places you never knew existed if you do it right.
Also: Unless you wear gloves, you WILL GET BLISTERS just below the base of each finger (excluding thumbs). Depending on how tight your shoes are and the nature of the straps on the rower (not to mention how vigorously you row), you might get blisters on your toes or just above your heels (Achilles tendon area). DEAL. Sorry if I seem like a jacka$$, but you have no idea how many people I've introduced to rowing who have come back crying about this.
Not much you can do about the hands aside from gloves (no adhesive cushion will stay on while rowing), but I've found
these to work well for the foot/heel blisters. They'll prevent any that pop up from receiving more damage even while rowing. Can be found at any major drug store. Pretty expensive but they do wonders for blisters.
Diagram of Muscles Used:
http://www.concept2.com/us/training/tools/musclesused.asp
As for selecting a machine, keep in mind there are several types of resistance mechanisms out there. The best are actually indoor boats where you're sitting in a small pool (stationary, but surrounded by water with real oars). Good luck finding one of those though. Most common are:
Flywheel (aka "Fan"): These use air resistance, and are the most realistic next to the indoor boats listed above. These are also the most widely used in gyms and on crew teams.
Magnetic: These are the smoothest and quietest, but don't simulate inertia as well (Each stroke is comparable in resistance to the last, as if the boat had come to a complete standstill after each stroke). This might be better for you, since you're going for muscle building (on the flywheel you'll just have to pull harder).
Hydraulic: Old-skool, and from my experience virtually no inertia simulation. Not very smooth either IMO.
As for the dampener setting, think of it like this:
At 1-3 you're in a fast, streamlined crew skimmer.
At 10, you're in a fata$$ rowboat.
