Turkish
Originally posted by: iamwiz82
Originally posted by: Xiety
Originally posted by: Whade
Headlights - anywhere between $200 to $400
For a headlight? Try $20
Low Steering Power - anywhere between $48 to $500
Dunno about this but does it just need power steering fluid?
Wheel Bearing - anywhere between $150 to $1000
Seems high for a bearing? I'm not a mechanic but you can get a new wheel for $150.
What I mean by headlights is the whole left headlight unit is broken, he showed it to me, it's all taped so it wont fall off... i dunno...
about the power steering, yeah he said the power steering fluid was leaking, he said it might be as cheap as $48 but it can go as high as $500 to fix it...
and about steering bearing, I know that sounds definetly high, maybe this guy really is trying to screw me 🙁
a wheel bearing is not hard to replace. Go to a junkyard and get a used headlight. What is leaking in the steering? I replaced the entire power steering of my Jeep for $150, including resevoir, pump, pulley, and steering box.
thanks for the advice but this is a really small college town, i don't know where i would find a junk yard at... who or where should i ask? probably the mechanic knows it i guess? hmm i will be pretty happy if my power steering costs around that because what the mechanic told me is so much higher 🙁
