I am in need of a sub
vi edit
62,484
8,345
PE has some excellent drivers. The RS is a hell of a speaker for $150. But their electronics (amps) are a bit suspect (ground loop hum) and boxes are not that great for the money. The cases in particular are far overpriced and under braced. It's the bracing that is key in the boxes. Deadening resonance and making it solid to eliminate some of the "muddy" sound that others describe. The driver itself is very low distortion. But a cheap and poorly constructed box can make it sound like crap.
Anubis
78,712
427
tbqhwy.com
looking at them from what little i know about building sub boxes i agree, i just have no idea how to build a proper one, unless it comes with instructions for idiots like the TH one linked above
any issue with laying that on its side?
vi edit
62,484
8,345
Check this out:
http://zaphaudio.com/archives-20.zip
That's a link to the zip file of cut plans and images from a guy who does a lot of cabinet modeling and speaker building. I used it as a reference for my build of my Dayton RS 12" build. It's over 60 pounds of subwoofer and almost entirely "dead" as far as resonance goes. Sounds great and was pretty easy to put together.
Kaido
Feb 14, 2004
51,959
7,412
The one I linked has a bit more tuning/EQ'ing function to it.
And no, not ported. Sealed. One I like it better for music. Two it's much easier to build. Three, less chance of bottoming out your sub and damaging it like a ported one.
For music purposes where you aren't trying to get maximum extension and/or output I just like the simplicity of sealed. No question on the performance gains going ported for HT use where the extension and output is more needed.
Interesting. I'm actually in the process of building a pair of 8" subs with the cheapo Dayton drivers - one is ported, the other is sealed. I wanted to see what the difference was in a side-by-side comparison.
Kaido
Feb 14, 2004
51,959
7,412
Are there any other sources for lower-end mono amps for subs? I'm using a BASH 300w in my Sonosub, but I have a lot of little projects lined up for the Dayton 25w, 70w, 100w, etc. amps. The BASH models are available in 300 & 500w, but some of these projects are far more budget-oriented and don't require as much power.
Howard
47,982
11
Parts Express has some cheap plate amps. You can also sometimes find decent plate amps on apexjr.com or ebay.
You don't want to get a regular amp because building the power supply isn't very fun or cheap.
vi edit
62,484
8,345
with this approach do you need an a HP filter like you do with the tapered horn linked above? MiniDPSs arent hard to work with or expensive, just curious if its needed here or the amp takes care of it for you
You could use one, but it's no where as important as in vented enclosures. The air spring of the sealed enclosure offers a pretty good amount of protection. Not to say you can't bottom your sub out by being stupid, but you'd have to try to do that.
Anubis
78,712
427
tbqhwy.com
alright, think i may give that a go. building that box should not be hard. prob wont make an elaborate faceplate like he did but the rest of the 18x18 cube is pretty straight foreword
vi edit
62,484
8,345
If you have access to a table saw, a router, circle jig, and jig saw then it's cake.
I've got "fatman" and "little boy" in my HT setup...
https://public.bay.livefilestore.co...9_qDSQABU1dKWPRCXK68pOleQ/IMG_3917.JPG?psid=1
And honestly...That little seal box can pound out some very clean, loud bass. I actually am considering ditching the big ass MFW and building a second, sealed 15" version of the Dayton RS. it's just a very, very low distortion driver that sounds excellent. Doesn't have the excursion or power handling of other drivers, but it just sounds very good.
glen
15,995
Did you build that from a kit or from scratch?
vi edit
62,484
8,345
From scratch. It's just a sheet of MDF ripped down, butt joints that are glued & clamped. Used plywood for the internal bracing. Used a circle jig and a router to cut out the holes. Then did a roundover bit on the edges of the holes. Then took a 45 degree bevel bit and routed off the edges of the box to make it less...boxy. I just have a simple black latex enamel that I painted it in. Nothing fancy and certainly not flawless...but it's in a very dark room and not really on display. Built for purpose, not for beauty. :D
Anubis
78,712
427
tbqhwy.com
yea already know about the circle jig, impressive the elmers wood glue holds that together without the aide of screws, figured you would have used something a bit more serious like PL premium
vi edit
62,484
8,345
Nope. Wood glue is crazy stuff. It's actually got a better bite than nails do. You don't want to drill/nail into the ends of MDF. It'll split/crack like crazy. The only reason to use nails or screws is to hold it together while you set your clamps. But that's not even necessary.
Anubis
78,712
427
tbqhwy.com
yea ive worked with MDF before, it splits like cardboard when you do stuff to the ends of it, well because it basically is very thick layered cardboard
Howard
47,982
11
I find that the easiest way for me to set up the gluing is to actually dry-clamp the boards together precisely, and then pilot drill into the butt joints so that I can use drywall screws as combination aligning pins/clamps during the actual gluing. I always put the clamps back on after the screws are tightened though, as insurance.
This way, glue setup is very clean and easy. Be sure to select a drill size that is equal in diameter to the shank (minor diameter) of the screws you use if you want to do it this way, though, since even a slight interference fit will cause splitting.
