- Feb 24, 2006
- 7,881
- 549
- 126
even if you are going to leave it matte, you should still sand it down a bit then apply another coat.
Absolutely, this thing will be getting 2 or 3 more coats of paint.
I wonder if the "rattle" is actually your driver hitting it's mechanical x-max from overexcursion. By your descriptions I would imagine so.
I would think that he's driving the sub with too much energy below the tuning point, but he's got it set pretty low... Are you sure your slot is the right length or if you have the proper end correction factors? Try to measure the impedance or the frequency response to see if you match your simulation.
By the way you don't want to be in a hurry when you live in Canada and need surgery but that is a different story.
The fucking Amp craped out tonight! The sub volume control no longer works.
I am going to call CSS tomorrow.
More later.
I am starting to think it's the user![]()
I took the Amp out and check the circuit boards for dust. It looked reasonably clean. I blew canned air on the circuits verry carefully making sure I was not freezing anything.
I checked all the connectors and they are all properly seated.
I seated the amp back int it's hole on the box, installed 2 screws to secure it and plugged it in. It worked OK
As I was putting the rest to the screws in, as I tightened this screw, the sub started acting up. When I loosened it it works OK.
Disconnected everything, took the amp out, plugged everything back and turned it on. As soon as I bend the aluminum plate around that screw, I get the problem.
If I bend or twist this circuit board a little bit I get the problem
Well at least I can duplicate the problem now.
There is a short somewhere that happens when you tighten it. check which way the panel flexes and look for cold solder.
Did you not take back that White Van stuff yet?
With the amount of time, money, and effort that's gone into this so far, I imagine you would have been better off getting some quality Internet Direct subs.
