I am going to build a subwoofer.
viivo
3,345
32
Good luck! Be sure to take lots of pictures and post your progress. I'd love to do something like this, but I'm too worried about ending up with a crooked box with air leaks all over the place.
Also, how are you planning on cutting the hole for the sub? Jigsaw?
sdifox
100,288
17,903
I ordered the Amp and Driver today from CSS
Total $381.94 including shipping and taxes.
BASH300
TRIO12
I also purchased some hardware at the local store
Wood Glue
T-Nuts, bolts and washers to fasten the driver.
Saw Guide
SheetRock screws
Drill bits for the T-Nut and for pre-drilling the screw holes.
Total for hardware $42.43
Ill get the 3"MDF sheet tomorrow and start building the box.
check your local lumber yard to see if they do cuts for you. Some places (like Home Depot) allow up to 3 cuts per sheet.
vi edit
62,484
8,345
MDF + T-Nuts = bad combo. It's virtually impossible to get them hammered in, and once they do they can easily strip out. I'd make that inner layer of the manifold out of plywood since you'll get a better grip with it.
Also, get/borrow a router and make a jig to do the holes.
Number1
7,881
549
I could not fit my reciprocating saw to the saw guide so I returned it. My dad gave me a router many many years ago. I build a jig for it and tried it on a piece of wood. I was able to make a perfect circle. The only issue is with the 3/4 in MDF I am going to have to go over twice as the bit is not tick enough to go trough the wood.
Number1
7,881
549
I experimented with the T-Nut and as long as I don't apply to much torque it should be OK.
I don't have 3/4 in plywood so I am going to stick with the MDF.
Number1
7,881
549
I put the pieces together loosely just to see how they woulf fit. Looking pretty good so far. I might have to do a bit of sanding on some parts.
Number1
7,881
549
I will cut the speaker holes and the braces today , fit everything together with screws and make the necessary adjustments.
Once I am happy with the fit, Ill take it all apart again and reassemble it using wood glue.
I got confirmation for my order and it shipped yesterday. I expect to get this here by next Friday.
It is COLD out there today!! -15C, -21 with the windchill. BRRR, I love my wood stove.
Wood heat is a bit messy but I can keep the house as hot as I want without worrying about the bill.
Number1
7,881
549
Here are the inside boards. Nothing that a good sander can't fix. As long as all my inside pieces are the same width, I should gat a good fit.
Number1
7,881
549
I got a new cordless drill for Xmas and I love it. I used it all day yesterday. All of a sudden it just quit working so I put it on the charger but instead of charging it gave me a red flashing light saying the batery is defective!!! Eventually it did recharge and it seams to be working OK this morning. It uses a Li-Ion 18 V battery. Should I return this drill and get a new one or is this the way Li-Ion batteries behave? Its worth $200. and so far it's the best frill I have ever owned. The best thing about it is the brake that stops the drill from turning as soon as you release the trigger. One hand key less chuck is absolutely fantastic.
sdifox
100,288
17,903
Return the sucker. If the battery says defective now, it is not a good sign.
Number1
7,881
549
I uploaded a bunch of pictures on my smug mug account. The box is coming along real well.
Check it out starting at page 7: SmugMug
It is a lot of work. It was tricky to put the silicone on the joint in the vent (the slot at the bottom). I had to use a small 2 ft stick and put silicone on the tip and smear it on the joint. It's crude but it got the job done.
The plan for tomorrow is to finish sealing the joints in the vent, install the last 2 braces, install and seal the top cover and the front baffle, start filling the screw holes with mud and start sanding the outside to get it ready for painting.
I also have to find legs for the box to rest on as the woofer will be pointing downward.
I can't wait to give this baby a try.
Soundmanred
10,780
IMO, too much bracing (sounds weird, huh?) and too skinny of a slot port.
I hope it sounds good though!
Number1
7,881
549
The slot is 16" wide by 1.25" thick by 36.7" long. The air velocity is down to about 18 M/S (BassBox 6), well bellow anything I could achieve with a round port of reasonable length and diameter. Exemple, the air velocity was at 28 M/s with a 20" in long 4" round port.
I did notice the air velocity went way up if the slot was less then an inch thick but it is OK at 1.25.
As for the bracing I don't think it will hurt anything.
Number1
7,881
549
I got my parts in today.
I did a bunch of work on the box, put the Amp and driver in and hooked it up to my receiver about a hour ago.
OMG the difference is like going from low definition TV to high definition.
The hole house is shaking
The dog was scared and was barking at the sub!! LOL
Music is "very" nice.
I put the movie "Number 9" on because it has good DTS sound effects.
WOW, did I say WOW!!!
You can feel the explosions, you can feel the earth shake in the action scenes. Mind blowing.
The hole system sounds completely different. Better is an understatement.
Well worth the trouble.
Picture to follow.
vi edit
62,484
8,345
Ha! Enjoy the feeling while it lasts. In three months your're going to want to feed your inner bass head even more.
:D
Next up for you is a table tuba.
Number1
7,881
549
:D
It won't be a tuba but I already have plans for an improved version. This one here my very well end up at my son's place. He happens to need a sub.
You can see more pictures at my SmugMug gallery.
I kind of get a trill at the dog barking at the sub, LOL
Number1
7,881
549
OK the initial excitement is over. It sounded good BUT there is a rattle, a loud rattle.
I don't know how to fix it yet, if it's fixable :-(
I think it comes from the front baffle where the driver mounts. It's 2 boards of MDF sandwiched, glued and screwed together.
If I push down on the magnet hard with my hand, the rattle goes away.
More to come...........
0roo0roo
64,795
84
ah canadian..
never seen that glue brand in the us.
and lol at the dog freaking out. should hold him on the couch while u blast it for a bit till he gets used to it.
Number1
7,881
549
I received the new surrounds for my wharfedales mid range speakers. It took 48 hours to put them in and wait for the glue to dry. I am happy to report they are working great.
LOL
Now back to my sub, I think I have a solution for my issue.
