MongGrel
- Dec 3, 2013
- 38,466
- 3,067
- 121
So, I went ahead and bought an NH-D15S, arriving today. Is it it overkill? Definitely. However, that also means that I won't ever need to replace it no matter what CPU I get in the future.![]()
If it fits ok that will really solve the problem.
And quieter than most, have been using a NH-D14 for many years myself.
:thumbsup::thumbsup:
Just run mine vertical shooting up at the 200mm fan in the top of the old Antec 1200 , just had to move the fan from the front to the rear, it runs pull/pull basically with the others pulling from the side out to the rear.
The 200mm in the top is the only fan not modded in this old thing
