AyashiKaibutsu
Damn it my college better not bend over and take it from another hurricane : (
Originally posted by: SP33Demon
How often are your local weather forecasters right? :roll:Originally posted by: Doggiedog
Can't these weather people get anything right?
They had this thing going out to sea and Ivan hitting Tampa.
If I was as wrong as these meteorologists are I'd be out of a job a long time ago.
You guys do realize that the weathermen don't actually predict anything, right? They give you what the computer models spit out.Originally posted by: Doggiedog
Are you asking this as a serious question?
They are never right. You know how many weekends they've ruined by saying its going to be nice and it rains and vice versa? How about all the snow storms they predicted that never materialized or snow storms that dumped a ton of snow that they said would have little or no accumulation. These guys can't even predict one day out it seems.
Depending on the conditions, the models can be right.. or wrong. There are so many variables that it is nearly impossible, unless the weather is in a steady pattern..
The models can generally predict 24 hours into the future realitivly accurately.. I don't have any figures though, that would be an interesting study.
But you'll notice that unless, as I said.. the weather pattern is steady, the later days in the long range forecasts will almost always change each day, sometimes each forecast... the weather is just too turbulent, so to speak.. but the more we predict and are wrong, the more we can correct our mistakes and theoretically the more accurate we will get..
The ultimate will be some sort of weather supercomputer that basically calculates weather by using data from the whole globe. That will probably be a huge advancement.
Yeah, that's true I suppose. What I was kinda getting at, though.. is some sort of technology that could watch every square mile of the globe. If you could compute with that ammount of data, accuracy would probably go up a bit.. assuming we know how the things at play actually.. play, and implement that into the models correctly..Originally posted by: DrPizza
Not a huge advancement because the other local variables would have more of an effect on the weather 2 days down the road than the weather half way around the world. The problem with weather forecasting is chaos. We cannot make enough precise enough measurements to predict more than a couple of days in advance with any reasonable amount of accuracy. Nonetheless, there's public demand for forecasts 7 or even 10 days in advance. It's pointless to provide those predictions, because random guessing is probably just as accurate... but you've gotta keep the masses happy. Plus, with their short attention spans, they usually forget 5 days later what you predicted 10 days in advance.
Originally posted by: waitman
That's my wifes name and just like her, she can become a hurricane at any time. She has a blackbelt in taikwondo!
They are forecasting strengthening (although it should be Cat 3 or less). 😉Originally posted by: Kenazo
On the upside for Florida, this isn't a terribly strong hurricane, right?
I was sarcastic because usually forecasters are dead on regarding the weather within at least a day. To expect them to predict something like a hurricane, that even our supercomputers don't have all the variables for, and its 3-5 day forecasted path is ridiculous. Even within a day we cannot say 100% what a hurricane will do or go, as demonstrated by Ivan. Usually they are right 80%-90% of the time with the weather forecast for the next day, so cut them a break.Originally posted by: Doggiedog
Originally posted by: dullard
As far as I know, I'm the only one at Anandtech who actually uses programs similar to weather prediction programs. These programs are not very accurate.
1) We simply don't have the basic theory. Without the theory, how can we write a computer code, and how can anyone expect that code to be highly accurate? A lot of the theory is quite good, but when it comes to turbulence in the atmosphere there is NO good theory.
2) We simply don't have the computer power. A simple sounding calculation like airflow around a building may take days or weeks for typical supercomputers to solve. When it comes to weather we don't have weeks (how useful would a great computer prediction for last weeks weather be?) Thus they have to dramatically oversimplify the calculations - leading to errors even if the theory was perfect.
3) We simply don't have the raw data even if #1 and #2 were perfect. We have official data at every airport - and basically nothing else. Data for wind speed, direction, humidity, temperature isn't known in very many locations. Even worse: most of the data collected is just along the ground very few weather ballons are used to get data in middle or upper atmosphere.
4) Even if we could get the billions+ of data points needed for accurate predictions, we don't have the infastructure to get all those individual data points to every single weatherman's computers.
Actually the programs are quite accurate . . . for the data inputted. Looking back (in hindsight) we can see where the models went "wrong" and often it is the intrepretation of them. 😉Originally posted by: dullard
SATELLITE IMAGERY EARLIER THIS MORNING INDICATED A WELL-DEFINED
CLOUD-FREE EYE WITH A RING OF COLD TOPS SURROUNDING THE EYE. THE
DVORAK INTENSITY ESTIMATE WAS A CONSENSUS T5.5...OR 102 KT...FROM
ALL THREE SATELLITE AGENCIES. HOWEVER...DURING THE PAST COUPLE OF
HOURS...CLOUD TOPS HAVE SIGNIFICANTLY WARMED AND THE EYE HAS BECOME
A LITTLE MORE RAGGED. AS SUCH...THE INTENSITY IS ONLY BEING
INCREASED TO 90 KT FOR THIS ADVISORY.
THE INITIAL MOTION IS A SOMEWHAT UNCERTAIN 270/4. JEANNE IS
SURROUNDED BY HIGH PRESSURE EVERYWHERE BUT THE SOUTH...SO THERE HAS
BEEN LITTLE IN THE WAY OF DEFINITIVE MOVEMENT THE PAST 6 HOURS.
HOWEVER...ALL OF THE AVAILABLE NHC MODEL GUIDANCE INDICATES THE
PRESSURES TO THE WEST OF JEANNE SHOULD BEGIN TO DECREASE AS IVAN
MOVES NORTHWESTWARD AND THAT SHOULD ALLOW FOR A SLOW WESTWARD
MOTION TO BEGIN SHORTLY. IN THE LONGER TERM...THE TROUGH-RIDGE
PATTERN OVER THE CENTRAL AND EASTERN U.S. AND INTO THE CENTRAL
ATLANTIC IS FORECAST TO AMPLIFY BY ALL OF THE GLOBAL MODELS. THIS
RESULTS IN A RIDGE BETWEEN BERMUDA AND THE U.S. MID-ATLANTIC COAST
TO REMAIN NEARLY STATIONARY THE NEXT 48-72 HOURS WHILE BUILDING
SLOWLY SOUTHWARD. A DEEP-LAYER EASTERLY FLOW REGIME IS EXPECTED TO
MOVE JEANNE WESTWARD FOR THE NEXT 48-60 HOURS...WITH A POSSIBLE
TURN TO THE NORTHWEST AS THE HURRICANE NEARS THE FLORIDA EAST COAST
IN ABOUT 72 HOURS. THE OFFICIAL TRACK WAS NUDGED WESTWARD OUT OF
RESPECT FOR THE NOGAPS AND GFDN MODELS...WHICH WERE FIRST TWO
MODELS AND THE MOST CONSISTENT ONES TO INDICATE A WESTWARD MOTION
TOWARD FLORIDA.
THE INTENSITY FORECAST IS STILL TRICKY. OCEAN CONDITIONS NEAR JEANNE
ARE CURRENTLY NOT FAVORABLE FOR SIGNIFICANT STRENGTHENING TO OCCUR.
HOWEVER...BY 24-48 HOURS...THE OUTFLOW PATTERN IS EXPECTED TO
IMPROVE AND JEANNE IS FORECAST TO MOVE OVER WARMER WATER NEAR THE
BAHAMAS. THIS SHOULD ALLOW FOR SOME ADDITIONAL STRENGTHENING TO
OCCUR. BY 72 HOURS...JUST PRIOR TO LANDFALL...INCREASING SOUTH TO
SOUTHWESTERLY UPPER-LEVEL SHEAR MAY BRING ABOUT SOME SIGNIFICANT
WEAKENING...BUT THIS IS TOO CLOSE TO CALL RIGHT NOW.
GIVEN THE FORECAST OF THE STEERING CURRENTS...FLORIDA SHOULD PAY
CLOSE ATTENTION TO THE EVOLUTION OF JEANNE.
Yes, chaos theory is very interesting and I'm sure it has some validity to it. The theory is that a butterfly somewhere flaps its wings, and this acts as the catalyst for a chain of events that eventually leads to a tornado. While I personally am skeptical about this, I think other things such as our NOX gases play a humongous role. The fact that the ocean is rising and cities are usually 5-10 degrees hotter ("heat islands") accentuates this fact.Originally posted by: DrPizza
On ABC 7 in NY earlier this week, I thought it was hilarious that an anchorwoman said "let's turn to the guess-ologist now for weather". He didn't take that too kindly but made light of it using sarcasm... his entire segment.Originally posted by: Doggiedog
Accuracy is relative. Take the snow question above as an example. It comes down to resolution. If you have great data from a few points which may be hundreds of miles apart, it becomes very difficult to get the weather accurate down to the mile resolution that affects people. They often predict a storm very accurately in many aspects (size, intensity, amount of precipitation) but they may be off by 10 miles to the south. In one sense, that is a huge accomplishment - they succeeded with so many things. But in another sense, they predicted 4-12 inches of snow (which probably occured ~10 miles away) for the user who saw 36 inches. On a personal scale, accuracy is miserable. In the big picture, accuracy is quite good.Originally posted by: apoppin
Hurricane predicting IS getting better . . . there just isn't enough resources devoted to them (or the weather in general)
Do you pay attention when they say 10, 20, or 30% chance of rain even though they forecast it to be cloudy? Even if it rained, I would still consider that to be "right" because they said there was a chance of it, so you should plan accordingly. If you are saying that they forecasted, on Friday, that the next day would be sunny and then it rained on Saturday, then that would be "wrong". In my old age I have rarely seen forecasters get the weather wrong for the next day.Originally posted by: Doggiedog
Again, I completely disagree. If the weather is clear, they are usually right. If the weather is uncertain, I'd say they are wrong almost all the time even 1 day out. I am not kidding when I say they were wrong almost every single weekend this year with their predictions even one day out.
How often would you say forecasters get the weather "wrong" within a 24 hr period?Originally posted by: dullard
24 hr is a lot better than 3 day, 5 day, etc.Originally posted by: SP33Demon
That is the hardest to predict. If they say it is 80% chance of rain, and it does rain but just 2 miles away from you, were they incorrect? Or did they make a damn good prediction just 2 miles off?Originally posted by: Doggiedog
Of course I look at it. When it says 70-80% chance of rain and it doesn't rain or it says 10-20% chance of rain and it rains are they right? Maybe technically but its still wrong.
