jeremycobert
- May 25, 2005
- 3
- 0
- 0
hey facemask,
i used the alchemy6.0 rca v3018sv as it says on the first post. i used this firmware on both the gateway and client routers. after the main router is running i unhooked my wireless card in my laptop and started working on the client, using the wrt54(client) as the nic card. follow all the steps in post 1, here is a pic of my clients setup.
picture of my client setup
so the first network can use 192.168.1.1 through 192.168.1.28 then the second network (subnet) starts on 192.168.1.129 through 192.168.1.254.
its easy to forward the ports, i let the client router get ip 192.168.1.2 , on the main router(192.168.1.1) i forward my replaytv sharing port to the clients address x.x.x.2, then on the client i forwad the same port to my replaytv at 192.168.1.151 (you may notice that i start the IP's at x.x.x.150, thats just to keep things straight in my head.
i use grc's shield up to test my port, use the custom probe port and your port number. it will say if its open or hidden.
poopli updater seems to search over the network and its subnet, so i just let it auto add. and its working, along with poopli sharing
dvarchive will only search for RTV's on its network so it has trouble finding it on the other network (the subnet) but you can just tell it where its located and then it will open up you RTV. i runs at about 290KB/s which is close to 300, so im happy with it.
i hope i helped ya,
i hope i helped ya,
