Originally posted by: cEvin Ki
@TheDrake:
based on what those articles indicate, i really do think that is what's happening. now, i do not know for sure, as i am not an IT tech.
but it would make sense, if behind the scenes, the memory was really running at that actual NB frequency, and therefore was entirely too overclocked. also, since you have the Sandra suite, one of those posts indicated that Sandra gave the true FSB speed in it's system specs display. look at that above highlighted link, post #2, at his screenshots. (the "mainboard" tab in Sandra, as compared to what CPU-Z displays.) i'm curious as to what your's reads.
i'd do it too, but since i rebuilt my system late 07, i've not played with Sandra at all.
i ran some numbers last night too. if you do use frequencies between say around 350 to 399 for the FSB, it would seem to work mathematically if you used a lower multiplier than 9. for example, 9/8 X 366 = 411.75 Mhz. could this perhaps be why a system using this FSB will work, but at a multiplier of *9*, NOTHING will make mine POST at 366?
i am itching to experiment!
Yep, your deduction was right! in Sandra it was reading the FSB at the higher rated than what CPU-Z was reading, very interesting indeed. In my attempt to lower the FSB and up the multiplier I really didn't have much luck. It seems as though I can get it to post between 370-390 when the memory is at 1:1, but if I try to up it to 5:4 then no go at all even though its still well below what the DIMMs are rated at. I can certainly get it to post above 400 but then I get into CPU stability issues. I can get 3.9 GHz to post ~ 433 with 9x multiplier but thats about it, lol. It is no where near stable. I can drop it down to 410 ~ 3.7Ghz, but I think this processor will only do 3.6Ghz stable within safe temperatures on air cooled. So my best bet seems to be the 450 FSB 8x multiplier with memory at 1:1. I was hoping I could get some more out of this memory but thats alright, it was cheap so you get what you pay for
This is very interesting behavior that I havent seen before! Its always fun to learn though! Thanks again graysky for this great thread and help. Thanks cEvin Ki as well for pointing out what I didnt put together, this would have driven me crazy if I couldnt figure it out, lol.
 Facebook
Facebook Twitter
Twitter
