Yes, use the Loctite kit. It is better. Clean both the glass and the button, with a new straight edge razor blade. Then wipe them both with alcohol. Apply the primer to the glass and the button. Then apply the glue to the button. How much glue depends on the size of the button. If it's a standard GM, Ford, Chrys., size button, I run a single line of glue about a 1/16" wide, vertically, the entire length of the button. When applied, the glue should spread out the entire width of the button. If it is a bigger button, just use multible lines of glue, depending on the size. When applying the button to the glass, make sure you carefully line it up where you want it, and after making contact with the glass, hold it in place for about 30-60 seconds. Also, once you have made contact with the glass, do not move the button even a little, until it has taken a set (30-60 seconds).
