Jeff7
- Jan 4, 2001
- 41,596
- 20
- 81
Yes, I'm aware that popcorn pops because of the water inside. That's why I made the comment about changing the specific heat of water.Originally posted by: SlickSnake
From American Heritage:
"The NJRC tube brought a critical benefit to the oven. As Ironfield recalls, it had ?a very modest heater power, 65 watts.? And it was about 65 percent efficient, which made it fit into a 15-amp household circuit.?
Pretty tame compared to modern 1200 watt or more microwaves. Of course, some early microwave units consumed 3kW, too!
Now, just off the top of my pointy head, I would imagine the first megnetron tubes they were using for radar research and then oven research in the 1940s were most likely the 6kW magnetrons. But for a simple oven, that kind of wattage would be insane. Most likely they were doing early oven experiments in the 3kW range, but I could not confirm this anywhere.
The reason it takes longer on some microwaves than others to pop corn is more related to the way the individual magnetrons work and the oven designs. I had a small 800 watt unit that cooked food a lot faster than an older 1600 watt one I had.
You really need the increased power of a modern microwave oven only to cook large quantities of food more evenly, not to pop a few tiny kernels of corn.
Popcorn.Org
"Popcorn's ability to pop lies in the fact that the kernels contain a small amount of water stored in a circle of soft starch inside the hard outer casing. When heated, the water expands, creating pressure within, until eventually the casing gives way, and the kernels explode and pop, allowing the water to escape as steam, turning the kernels inside out."
Welcome to the laws of physics.
Someone sure needs a reality check or another dose of one all right.
I suppose a better term would have been "heat of vaporization."
Either way, once you can change the laws of physics, get back to me.
A cellphone doesn't output directional energy. If it did, then it could probably pop a kernel of popcorn.
Now stop being such a darned Googtrog all the time, sheesh.:roll:
(BTW, I've not touched Google to reply to this thread. I also will only seek Google for specifics on information I already know. I don't need to "appear" smarter than I am.)
Why yes, yes I do notice. It's because the cellphone itself heats up considerably because of the power flowing through the antenna and other electronics. I'd imagine that holding a warm piece of plastic and metal against my skin would tend to warm up said skin. Imagine that.I guess you all never noticed how warm your ears and head get after using a cell phone? They pointed out in the article with the videos they thought it could be popped due to the standing waves from the multiple cell phones proximity. And since none of us can confirm or deny this factor, how about a little less criticism of myself for simply posting this topic, fellow googtrogs?
OMG! It's on Youtube so it must be real!!!!!!Originally posted by: binister
I totally believe it... Have you seen the what lies dormant inside cell phones?
I have... and it scares me![]()
I trust you accounted for all variables between yourself and the receiver tower? Trees blowing in the wind, possibly even traffic, radio interference from other sources, atmospheric distortion, etc? That's damn impressive by itself.Originally posted by: SlickSnake
As far as the cellphones go, they obviously have the capacity to transmit over great distances for such a lowly stated wattage. And I think they also share one other factor in common with the microwaves in that they appear to vary the power to the transmitterwhile in use. On some phones I have used in the same location, this is obvious as the signal meter goes up and down, all while remaining perfectly still, even if the phone is lying on a flat surface.
Well there you have it. Get back to us on the absorption profiles of those surfaces so we can characterize how they might affect the transmissions of a cellphone. I'd guess that you'll get a lot of the radiation passing through with no problem, otherwise you would get no reception in your house.Not being a cellphone engineer,.......
And when multiple phones are lying flat against a surface, depending on the surface they are on, like glass, metal or wood, it might intensify this rising and falling power output effect.
I just did my own little test:
Less than a teaspoon of water in a plastic spoon, with a thermocouple in it, with my cellphone pointed at it from a few inches away. I made a call and kept up activity for 2 minutes. It started at 25°C and ended at 24°C, because the room is cooler than that. If it could heat a small amount of water to boiling in a few seconds, I'd expect, at the very least a small increase in temperature from that kind of energy.
A few minutes later, I tried something else:
With the water down to 22°C, I put it against my hand. After less than a minute, it was up to 24°C, even after getting the heat through the insulating material of the plastic spoon.
If I knew a way of activating the antenna on my phone without using up minutes, I'd leave it running all night, and I bet you that there'd still be most of the water in the spoon. (My apartment is kept pretty dry, so a fair amount would evaporate naturally.)
