How much would a space elevator cost to build and how long would it take?
ViviTheMage
36,189
87
madgenius.com
Originally posted by: sdifox
Originally posted by: ViviTheMage
impossible!
the moon orbits, its never in the same spot .... so you would have to also build a track throughout the length of the world at which the thing could shimmy over, like a lil racecar as the moon orbits around.
fools!
who said anything about a space elevator to the moon? Just to space, so we don't need to rocket boost everything into orbit.
psssh, no destination = no fun!
manowar821
6,063
SPACE IS NOT ONE HUNDRED THOUSAND MILES AWAY.
Besides, it's completely possible, we just need to develop carbon nano-tube technologies to build the support cables.
I say a half trillion dollars and 5-10 years.
NL5
3,286
12
I think that post was meant as a joke........
manowar821
6,063
Oh... dammit... :eek:
:D
sandorski
70,677
6,250
The Cables/Tubes are going to be the biggest expense. I'm guessing between $1-10billion. I really don't think it will be very expensive, we just haven't perfected the Technology. It is likely the Ships used to get the Cargo at the top of the Elevator will cost more than the Elevator itself. I'm just guessing though, so whatever. :p
sandorski
70,677
6,250
Originally posted by: IcebergSlim
please explain to me the utility and payback to mankind for such a device.
Cheap/fast(ish) way to move things into Space.
darkxshade
13,749
I'm no rocket scientist but I'm thinking, isn't it possible to build a space station orbiting earth with a cable long enough to reach the floor of the earth and somehow use that as a means of hauling stuff into space instead of building a tall elevator from the ground up?
sandorski
70,677
6,250
That's basically what the Space Elevator is. Just a Base Orbiting in Space with Cables/Tubes reaching the ground and anchored there.
darkxshade
13,749
Seriously? What's all this crap I've been reading about plans and such that involve actually building one from the ground up?
Cuda1447
11,757
Originally posted by: conehead433
A physical impossibility. Under the sheer weight of a structure that tall the bottom of the structure would be liquefied.
Use triangles man, didn't you ever build that damn bridge in HS. Its all about the damn triangles!
sandorski
70,677
6,250
I dunno.
IceBergSLiM
29,932
Ok what are we needing to move cheaply and quickly into space?
silverpig
27,703
12
I participated in the NASA space elevator challenge, did a ton of research on it, and we built a robot and competed. Here's what I know.
So you can put objects into geosynchronous orbit. There are a lot of satellites in this orbit. The orbital period of something at geosync is 1 day so the satellite sits above a single spot on the earth's surface.
If you extend a cable down towards earth, and a balancing mass out into space, the center of mass of the cable is still at geosync so it orbits the earth once per day. If you make it rotate once per day as well, then the "low" end of the cable will stay on/near the earth's surface. This end of the cable doesn't support any weight so it can be arbitrarily thin. The strongest forces are at the center of mass, and this is where your cable needs its strength. Calculations have been done for a steel cable, and in order to not rip apart, the steel cable would have to have a diameter of about 10 miles at the center of mass. Yeah...
sandorski
70,677
6,250
Stuff! Hehe, at the moment, mostly just Satellites, but a Space Elevator would make Moon or other Planet Colonization much more viable by reducing the Cost of getting Stuff into Space.
BrownTown
5,314
I think it would be ~300 Billion dollars, but the point is its COMPLETELY WORTHLESS. We have no good reason whatsoever to be in space other than dick waving, and we can do that just fine here on earth by invading other countries and stuff.
Also, apparently most people here don't get the basic idea behind the elevator, its not a building we build UP to space, its a rope connecting between earth and a space station. The elevator is not under compression it is under tension. Imagine swinging a bucket of water around in a circle connected to a string. Thats the whole idea behind the thing, the only problem is getting a rope string enough (and long enough) to stretch from the earth all the way up to space. IF you know anything about how much it costs to launch payloads into space you will say that a gigantic rope miles long and a foot thick will cost tens or hundreds of billions to launch into space even IF we had a strong enough material to make it out of.
See the problem is that a moon colony would weight LESS than the elevator itself so it would be cheaper to just launch it all with rockets than building the elevator. A space elevator only becomes economical at some point where you have a need to launch thousands of tons into orbit every year and that is still at least 100 years off.
sandorski
70,677
6,250
There's a lot more to it than just Building Colonies. There's supplying the Colony, but also in the transport of Goods back to Earth. The Moon is rich in He3 for eg and asteroids have many rich deposits of all sorts of goodies.
erikistired
9,739
us when the planet explodes.
JTsyo
12,014
1,125
The actual elevator wouldn't be like what you see in a building. It would be something that can ride on the line(s) that are anchored between the ground and a station in space. Geo-sycn orbits are around 22,240 miles (fix'd). While a space elevator offers cheap transportation to space I don't think we're near the need for it. What we need now is a cheaper space shuttle.
EDIT: A 22,000 mile structure sounds much more difficult
