I meant for the connection where take and connect the two computers together to check.
This is what someone told me in another forum. What is true about this?
For 1Gbit LAN to work, you'll need GBLan adapters and cables (yes, these are different than
"Normal" CAT-5 cables) in all devices on your network, including switches & routers.
I did not think routers would affect it after it is hooked up to the switch.
My network goes like this. Internet in to a 2wire modem/router-----gig switch-----computer-- also from the gig switch------ to another switch in another room------ to another computer, bluray, denon 3808CI, NAS(soon).
Cat5 is rated for gigabit. There are Cat5e, Cat6 etc but for a simple patch to check, Cat5 is fine. The key to check is if all 8 wires are terminated. Some cheaper 'Cat 5' (which isn't spec) drops 2 of the pairs and connects only 2 pairs effectively forcing that cable to 100mbps only.
Auto MDX should handle the crossover needs on the 1gig nics. Ones that don't AutoMDX have become pretty rare.
When it comes to the network, you need 1GB hardware but not all devices need to be 1 Gig unless you have one of the super junk switches that drops to 100mbps if a single 100mbps device is attached.
Jumbo frames is different. All devices need to support what ever frame size you pick. The gain for Jumbo frames is pretty minimal except in situations where TCP/IP overhead becomes an issue. With home hardware, I really doubt that you are having that issue.
Your network design looks 'typical.' It can be better to pull drops back to a single switch but in most cases it won't matter much.
