How is trillian?
CasioTech
7,145
9
Originally posted by: Nik
Originally posted by: silverpig
GAIM > trillian
Originally posted by: AMDZen
Gaim > Trillian
nuff said
Gaim doesn't have *nearly* the number of features and available mods/bonuses that Trillian does.
probably true but not everyone needs their IM program to clean their house and give them a happy ending. i like mine to sit quietly in the taskbar until i need it and not take up resources.
What resources?
Hey man, did you check my site? Pro's/con's?
gopunk
29,239
i like it... not many cons, except you can't go invisible like you can in the new version of AIM. that's outweighed by the pros though, for me at least.
Quasmo
9,630
cons: Buddy Names are Huge... if you have over 50 buddies online you have to scroll to see them. It has alot of trouble with direct connects, video chat, and voice chat. Thats why I use dead aim. Plus I like tabbed IMs.
Tremulant
4,890
Have you tried Miranda IM?
I don't use it (I use AIM w/ Aim Ad Hack), but IIRC, Quixfire uses it and I don't think he's had any problems with it.
JoeKing
Trillian was hot in "The Hitchhikers Guide" wish I HAD brought a towel, if you know what I mean ;)
:Q
NikPreviousAcct
52,763
Trillian uses tabbed IM'ing. :) The number of buddies you can see without scrolling depends on your screen resolution. I see a crapload of buddies. I do have problems sending files back and forth, but that's what email's for :p
Crappopotamus
1,920
trillian kept losing my msn messages :( people would just not get my messages. and it used to have issues with file transfer, im not sure how far theyre come...
DeviousTrap
4,841
Uh, trillian does let you go invisible. Just click the little status icon for AIM then go to Set Status > Invisible.
NiKeFiDO
3,901
has all deadaim options, take up less ram than AIM, is an all in one program
con: only can send a person one file at a time :(
or read html in profiles
Quasmo
9,630
You cant send 600MBs over email... I also didn't list the tabbed windows with the other cons cause I knew it had it. But at 1280x1024... and I have 85 buddies online I really cant use trillian.
Kodiak
576
Pros: Everything
Cons: I liked the tooltips that showed when someone signed on :(
DeviousTrap
4,841
Originally posted by: Kodiak
Pros: Everything
Trillian has tooltips that you can turn on, which will show you everytime someone signs on or off...
no0b
3,804
Pro: All-in-one
Cons: bloated with too many options thus making it harder to find the right options.
I like GAIM simple and clean, but it could be better.
Cuda1447
11,757
Originally posted by: Ausm
I like trillian been using it for years now.
Ausm
Same, I tried gaim for a short period of time. I thought it sucked. Only beef I have with Trillian is it does take up a lot of resources, but keep in mind you've got AIM/MSN/Yahoo/ICQ/IRC all at your fingertips.
psiu
1,629
I used Trillian 0.74 up to patch I, however the new Trillian (3.1 is the most recent) sucks IMO. Slow, wussy noises, and just a generally annoying interface with changes for the sake of change (no benefit, just different).
I'm using Gaim now, I really preferred Trillian 0.74I, but since I don't think it's getting any updates I'll go with Gaim.
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
What i wanna know is what the hell is the difference between Windows Messenger and MSN Messenger?
nsafreak
7,093
Windows Messenger is a one way messaging system meant for use inside domains/LANS to communicate stuff like "The e-mail server will be going down for 2 hours for a software upgrade". It basically does one popup alert box on your screen.
MSN Messenger is a two way IM service.
JoeKing
one gives you teh AIDS and the other doesn't. I'm not going to tell you which one does...
