k, for fuck sakes
if you take a look at the wiki link I gave you (which you probably didn't even read), you can see that air at 100% humidity and 100C has a heat capacity double that of air at 0% humidity and 0C. did you know that its impossible to have 100% humidity at room temperatures? even if you have 80% humidity at room temperature (which is very hard because you would have dew everywhere) the heat capacity of the air is no where near double, its only double at 100C. bottom line is humidity DOES NOT AFFECT TEMPERATURES AT ALL.
look, im not gonna keep arguing with you. frankly i dont care, if you want to listen you listen, if you dont wanna learn then go buy an ultrasonic vaporizer, put it inside your case, and let us know if the temperatures change and if your computer still works.
edit
and lets not forget that your whole premise was that humidity will raise the temps and if your cpu is on the edge, it will over heat. yaaa thats exactly whats not gonna happen...
like I said, even on a super humid day (at the same ambient temperature) your cpu temperatures might actually drop a few decimals (maybe 0.1 or 0.2C), which like I have been trying to tell you, a poor sensor like the ones in computers will not even pick up.
edit
