Originally posted by: GreatDaleness
Originally posted by: MAME
Originally posted by: Overkiller
Do NOT get a sapphire card. they are so cheap b/c 1/2 the pipelines are disabled. Spend the extra $50 and get a full 9600 Pro. Thank you![]()
But is there a $50 difference in preformance as well?
And what kind of power supply do I need to power these newer computers??
the power supply you have now should do fine. The 9600pro doesn't draw that much power.
That is an utter lie about the Sapphire cards. Their cards are no different than any other ATI cards. In fact, they make the ATI branded cards as well. THey are cheaper because they don't advertise as much, have the same warranty, and are OEM rather than retail.
Ok then, Sapphire it is! But as for the power supply, mine is a generic 300 watt one I'm using with my Athlon 600. Are you sure that will power a new rig?
