ManBearPig
It's all in how clean you want it to be. If you had a dish installer come out they'd just drill a hole right through the side of your house, run the cable in, slap a plate on it, put a little foam insulation around the outside hole and call it day. Doesn't get much easier than that.
We can't give you exact numbers because every house is built different with different levels of complexity to wiring things.
Honestly I would be happy to make it be kinda messy for the time being. I still couldn't make it that simple, even if it was messy though. The room is on the opposite side of the house the satellite is. So at the very least, i'd drill a hole through the brick, end up in one bedroom, drag the wire through the floor and end up in the correct bedroom lol. 😱
