Johnbear007
- Jul 1, 2002
- 4,570
- 0
- 0
On an off note,
does anyone know what port age of empires 2 uses ?
47624 TCP
2300-2400 TCP
2300-2400 UDP
Thanks a bunch... now my router USR 8000a-02 calls port forwarding 'virtual server' and it has a spot for the port.. do I put a separate entry for all those ports?
Not too sure... I'm reading the manual on this page here & it doesn't say anything about being able to enter a range of IP's under the Virtual Server section.
But how would you enter 100 separate entries for ports 2300-2400?
However, it seems you can enter a range of IP's under the Special Applications section, but I'm not sure what you would enter for as the trigger...
Yeah, I'm pretty confused about the trigger thing myself, I think they are really vague about that. I don't understand it.
