Originally posted by: Zclyh3
That's why people who don't know how to shift need to practice more. Practice makes perfect.
While you are practicing your shifts please find me some manual transmissions rated for 700+HP. When I build my 351 drag car(Fox Body Mustang) if you can find a 700+HP manual to put in it I will do so.
I guess all these guys just can't drive a manual like you can.
Strip Terminator
AODE/4R70W Transmission
Racer's Choice, rated to 700 h.p. (Mine is rated for 1000 in the first three gears even though I will never have over 600HP)
Operation:
In response to demand from enthusiasts and racers, Lentech has developed a Transbrake Valve Body for the AODE/4R70W Transmission.
The resulting combination provides the reliability of custom fixed line pressure, which prevents delayed line rise and consequent slipping, and ensures positive clutch engagements.
The AODE/4R70W Strip Terminator Transmission incorporates a custom billet 1 piece input shaft and custom non-lock torque convertor for added reliability.
For Strip / Limited Street applications
Auxiliary transmission oil coolers are highly recommended.
Specifications:
Quality selected core, completely stripped, all major components washed and inspected for excessive wear
Significant jnumber of modifications in strategic areas for efficient clutch operation and life
Clutch cylinders modified for extra clutches
7 redlined 3-4 clutches
3 redlined intermediate clutches
5 redlined forward clutches
4 redlined reverse clutches
New redlined O/D band
All new seals, gaskets, and filter
New bushings and thrustwasher (where needed)
New intermediate one-way clutch and spiral lock ring
New low one-way clutch
Lentech AODE/4R70W Transbrake Valve Body (value $669 US)
New oil pan and bolts
Re-assembled with all critical clearances adjusted for high performance/racing use
Cast gray finish
10" or 9.5" Torque Converter (billet front cover design, custom stall speeds, all furnace brazed, needle thrust bearings through-out, balanced electronically - value $799 US - 2 yr. warranty)
Hardened billet 1 piece input shaft
Lockup eliminated for increased reliability
All complete units are dyno tested to insure a quality product
Delivery within continental U.S. included
1 year warranty
$3195 U.S. (plus refundable core deposit
