yea i unfortunately dont know what the BCLK voltage is called on gigabyte boards, you are probably bumping up against a BCLK wall at its given voltage, but i dont want to accidentally tell you to raise the wrong thing. just wait it out until tomorrow, you will get there. at least you got it to 3GHz. also, try testing your CPU stability with OCCT instead of prime 95. it uses the same algorithm as prime95 but it finds errors 10 times faster than prime 95, and if you want to do ultimate temperature tests + maximum CPU stability, you can try testing it with linpack. if your cpu can past 20 minutes of linpack on high (90% mem) in OCCT, it's probably stable lol. like i said before, i just dont use it because i dont have the airflow over my cooler, and heat builds up in the cooler until the CPU overheats. you shouldnt have that problem though, since you have more than twice the airflow over your cooler as me 😀. i also tend to test for about 20 times longer than i need to to determine stability, since i want to be able to run my rigs 24/7 stable for a week at full load if i want to without worry lol
