Originally posted by: Muadib
I'm looking at getting the Q6600, and would be quite happy if I could get it to 3.6Ghz. I'll get these then. Thanks bamacre!🙂Originally posted by: bamacre
Depends on what cpu you are using and whether or not you're overclocking.
If you are not OC'ing, just get the ST memory. If you are, consider what kind of OC you are looking for. The ST will have no problems getting a Q6600 up to 3.6Ghz (9x multiplier x 400mhz).
Just compute what your FSB should be and divide it by 2, and that should tell you, roughly, what speed memory you need. For example, the Q6600 has a 1066mhz FSB and needs 533mhz memory to hit its stock speed, and as well, an E8400 has a 1333mhz FSB and needs 667mhz memory to hit its stock speed.
I already got the Abit IP35-E. Waiting for this ram to come in is the only thing holding me up.Originally posted by: OfficeLinebacker
Just wanted to mention that with a SLACR, the Gigabyte P31 based board board got me to 3.6GHz with my q6600 in very short order:
http://www.newegg.com/Product/...x?Item=N82E16813128077
I used some relatively cheap DDR800 RAM.
Price down to $32, or $64 for 4GB kit.
Compared to 12-15 months ago, this is simply amazing. I remember trying to find 2GB kits of value DDR2-533 for less than $200.
Originally posted by: dralb
What will these OC to? I am looking to run them 1:1 at 450-475 FSB.
I had 4 sticks running at 938 with no problem... but, your mileage may vary.
Originally posted by: ItsAlive
I purchased 2 of these sticks back when it was $35 per stick and have them running in dual channel at 870mhz with default 1.8v. and default timings 5-5-5-15. So far have used them in 2 different systems and they've worked flawlessly. I might buy a few more of these, this price is ridiculous!
Originally posted by: cmv
Saw this over at Slick Deals:
2 x 2GB DDR2-800 Super Talent (with Blue Spreaders) for $45 shipped after $30 rebate.
http://www.newegg.com/Product/...x?Item=N82E16820609218
Good deal...and made in the USA to boot. Awsome on that aspect alone!!!
Are yours the ones with the dark blue heat spreaders or the Silver heat spreaders? Because I know that the dark blue ones use 2.1v but default on the Silver ones is 1.8v. I havent needed to increase voltage as these are stable at this speed on 1.8v.
Mine are the 2GB sticks linked in the OP. I purchased them last year tho, so they may have changed the specs on them.
