Originally posted by: mistwolf
Nevermind, got one, thanks to a hint in another thread about google. 🙂
Jamie
care to share the hint? 🙂
Jamie
Originally posted by: skywhr
sold out
Originally posted by: kermalou
anybody get theirs yet, from online orders?
Originally posted by: MowSow
hhhmm out of 152 users, 57% said that it was a POS ! some of the comments .. Buggy even with upgrade and too simplistic, Worthless, even after firmware upgrade it still does not work, Wireless connection drops...poor support, Continually locks up internet connection, Make the Hurting stop!, Internet Locks Up, Lots of crashs and bad VPN support, Very bad router, There are HW defects in the 2623, Don't do it - buy ANYTHING ELSE!, This is a stinker, unreliable Wireless Connections and Bad Support, Resetting every 5 minutes.. or less, DONT Buy it -- Trust me!!, Lowest quality product available, Would not work for more than a day at a time, Needs reboot all the time, What a headache!
These are the titles from several posts .. go the the review to read more about it !
Originally posted by: SinMen
How many wired and wireless device will it support in total? 4 at the same time? Or 4 wired ones plus many other wireless?
Originally posted by: RideFree
Went to a local OD yesterday, spoke to manager who took one from stock, rang it up and I was out the door in minutes. ?Now, do I cancel the online order? Ostensibly, yes.
Set it up in about ½hour including de-commissioning the Linksys BEFSR41. Works perfectly!
#1. I recommend assigning an administrative password...something with upper & lower case and a number or two. Don't use your dog's name unless it is ¦}*~!?¾ or something like the singer formerly known as ******'s "famous" moniker.
#2. It comes with WEP disabled. EVEN IF YOU ARE NOT USING WIRELESS, either disable the wireless part by disconnecting the antenna (at the least) or better yet, enable 128 bit WEP encription.
(If you leave the WEP at default, it is like standing in front of your church service with your hands in your pockets and your fly unzipped! Trust me...you do not want to do this, 'cause you will not even be wearing underwear!) (And besides that, your fruitcake will rust!):Q
#3. Understandably, you will not use this unit in any WiFi scenario without enabling WEP.
Other than that, it has four auto-sensing 10/100 RJ-45 connectors for the wireless impaired and a switchable RJ-45 for your WAN connection.
I hope this has helped someone from making a drastic error. There are hackers that drive-by, looking for WiFi with no WEP enabled. Makes sure you're not a victim.🙁
Perhaps it's because if all you've got is wireless connectivity, it would be a little tough gaining access to the admin area of the router with WEP enabled out of the box.Im not sure why wireless routers, by standard i believe, have wep disabled by default
FYI removing the antenna does not stop the radio signal. And you only lose about 1/3 of your range and even with a shortern range a wardriver with any sort of high gain antenna should still be able to pick it up. There should be a radio disable option, at least every router/AP I've seen has that option.either disable the wireless part by disconnecting the antenna (at the least) or better yet, enable 128 bit WEP encription.
Oh, another thing (well, two)...
Since these are obviously meant for WAN connections, you better be running a firewall and antivirus software.![]()
I never said it was only meant for Wan connections. What I said was, "...obviously meant for WAN connections". The difference being...if all you want is an internal network connection, use a $10 hub. This unit is advertised as a "Wireless DSL/Cable Router". I think it is safe to assume that my original statement is correct.😉No, this isn't meant only for WAN connections. It has a built-in firewall.
I'd like to also be informed against known and unknown Internet threats; client logging for log filtering, sorting and real-time analysis.
I'd also like to have an alert advisor to know if there is an attack underway, etc., etc., etc.
Now, this sounds like a real firewall.
You are correct. Removing the antenna only curtails the emissions and does nothing to prevent their interception. Removing the antenna only restricts the transmission range.FYI removing the antenna does not stop the radio signal. And you only lose about 1/3 of your range and even with a shortern range a wardriver with any sort of high gain antenna should still be able to pick it up. There should be a radio disable option, at least every router/AP I've seen has that option.
where do I surrender?😀if MS wants the info bad enough, it's going to find a way eventually around firewalls, it's only a matter of time, best to give in now.
Yeh, like the attorney in the small town that starved 'till another attorney moved in at the other end of Main Street.Sounds like Zone alarm and Norton Internet security. Annoying products to say the least, half of "these so called attacks" are generated by the software I think...marketing gimmicks...
Seriously, with respect to this aspect of the control that ZAP gives, I have gladly shelled out my money every year for the past several years.such as, individual program control to allow me to block programs that have no need to access the internet, such as Word, Excel (heck, everything with the M$ label on it) Acrobat & damn near every recent program that I can think of, ad-infinitum
#1. Would you post the url for the "DSLreports" where the SpeedStream firmware/wireless problems have been posted?Been reading over @ DSLreports, sounds like there may be a serious problem with the firmware that may not be fixed by Siemens. Guess we will have to wait and see, think it has to do with the WEP enable VS. disable that you guys have been discussing.
