HOT! Boxed AMD Duron @950mhz. Final cost $70 shipped
eyor
Banned
Feb 7, 2000
1,641
I have a question: Why is everyone getting in on this deal? There are other places that have it cheaper, without coupons or having to buy two of them. Or am I missing something?
Bohemian
385
You're missing something. :) This is for retail box which comes with a full warranty and a heatsink/fan. The deals you speak of have no HSF, and warranties that are usually 15-30 days.
Jugernot
6,889
When you add shipping to those other places, they aren't cheaper. Most place stick it to your with shipping! $20 for ground shipping a CPU, YAH RIGHT!
eyor
Banned
Feb 7, 2000
1,641
okay, I was thinking of this one for $65 shipped, w/ 60 day warranty. What warranty does buy.com have?
also, I thought there might be a better chance that one of those is unlocked.
elSmoko
231
Askalon, generally speaking, you need pc133 ram to run amd stuff stable-like. I'm forced to stay with the more expensive and weaker performing celeron thanks to my 192 mb of pc100. If only I had a little foresight. oh well.
- El Smoko
eyor
Banned
Feb 7, 2000
1,641
But does pencilling in the bridges void the warranty? and would it be a better deal to get a $65 one without heatsink and fan or an $85 with heatsink, fan, and extra warranty? also, are buy.com's still unlockable? will they start sending out the new version soon?
abracadabra1
3,879
i've got a duron900@1.8V w/ abit kt7 mobo for sale. both are brand new, never used (except the cpu for testing).
$200 + shipping
Dznuts007
629
Anyone have any opinions of the Tornado1000 case from 3DCool.com? I know that it's kinda pricey, but the reviews seem really good. Any comments on that case?
hopster
366
I ordered 2 Duron 600s from Buy.com on the 11th and got them on the 15th. Both are week 29's unlockable (cut bridges). Still have yet to be tested (working too much)
ElDiablo
291
LuZeR
I've got the non-raid version of the kt7 and I'm not using any particular compound. The chrome orb came with a thermal pad and that's all I'm using. You'll probably want some paste though bc the pad doesn't quite cover all of the processor for some reason.
And the 877 is faster bc the memory bus is at 103 or 105 and therefore the processor is wasting fewer cycles.
Hope this helps
eyor
Banned
Feb 7, 2000
1,641
Search for "inwin." There was a thread with case deals in it two days ago.
gplracer
1,768
37
Good luck on the week 29's. I see a lot of people have them. I have two that I got from buy.com. Neither will work at 900mhz. They lock going into windows. I have to run them at 850 to get a stable system. Here are the specs for my system:
abit kt7
duron week 29 (two of them)
alpha pal 6035
mushkin pc 133 222 ram (128mb)
thermal paste used
The cpu's operate from about 38C at idle and 42-45C during operation. I turned the ram settings down and everything trying to get them to go faster but nothing will work. Do you have any ideas? The guy at overclockers workbench had two retail week 29's that did 1 gig at 1.75 volts. Currently mine is running at 1.825 volts. It does not help to run it at 1.85 volts. Help!!! Would I even be able to tell the difference at 900mhz? Do you guys put the cpu strength setting on 2 or 3 in the bios?
Bohemian
385
Oy! I have a very small home office network (3 PCs). I just tried to use the network for the first time since installing the KT7/Duron 600 combo and the network card is freaked bad. Reinstalled physically and drivers. are there known networking probs with the KT7? I recall someone else mentioning NIC probs.
gplracer
1,768
37
the apg slot shares with pci slot one. If you have an agp card do not put the nic card in slot one. Also slots 2 and 3 share. I heard soundblaster live cards do not like to shared with anything. I have my soundblaster live in slot 2 and my nic card in slot 5.
agheno
68
Hi guys, I'm trying to hit 1ghz and can't quite do it. Here are my specs, lemmie know of any suggestions.
Abit KT7-Raid
Duron 600 @ 9.5x100mhz 1.75v
Pal6035, artic silver thermal paste, 44° C idle
128mb Kingston ValueRAM PC100
8mb AGP TNT2 Vanta (overstock.com)
46gb ATA100
SB-Live
If I bump to 10x100, I get no video. I had this same problem at 8x100 1.6v but fixed it buy increasing the voltage. Unfortunately at 10x100, increasing to 1.85 doesn't help. I'm thinking it might be the video card that is limiting me from hitting the 1ghz mark.
Mr. Jag
JIZ76
143
eyor.............
<< But wouldn't overclocking/unlocking them void the warranty in any case? >>
Yes, Of course it does...
tigger80
1,198
antec ks282 case with 300w power supply works really well with athlon systems get it from onvia.com for 65 bucks with free shipping
jhassi
Banned
Aug 7, 2000
325
Dznuts007
<< Anyone have any opinions of the Tornado1000 case from 3DCool.com? I know that it's kinda pricey, but the reviews seem really good. Any comments on that case? >>
don't bother, it's cheaper to get a fleabay a full tower case and a couple of 120mm case fans, total will be ~$100 and it'll provide better cooling.
If you want I have a bunch of 130cfm 120mm case fans for $10 each, $3.55 shipping (usps priority with deliver comfirmation) for up to 3. look in my profile to find my e-mail
