Hum. Can you give a few examples? I have the same drive and have not yet had any problems.
Constantly changing? I thought Profile 1.1 went final last year. The only new "standard" is profile 2.0, but any 1.1 player will play BR movies with 2.0 profile as 2.0 only adds bd-live which isn't a requirement to play movies. Another profile coming out is 3.0, though 3.0 will just be an audio standard for audio only BR.
And in regards to firmware updates, to go with the profiles there are hardware requirements. If a BR player doesn't fit the hardware requirements for 1.1 or 2.0 there won't be firmware upgrades to make them compliant with those standards.
Which is probably why a PS3 is still considered the best BR player you can buy.
Perhaps I used the wrong terminology but disc playback with at least older Lite On drives (and many others) would require fairly frequent firmware updates for them to play the disc. I updated the firmware no less than 4 times (Although I am pretty sure it was 6) in the year I had it while they were providing firmware updates
My understanding is that the only new hardware required for profile 2.0 drives is:
1) An ethernet jack for internet connections
2) Extra storage for Live material
Does not seem like a stretch to enable 2.0 playback without the features of a drive
Furthermore my questions about why no new firmware would be provided was met with
"It's an older drive that we no longer support" not "We can't support it because it's 1.1"
