JoeBleed
- Jun 27, 2000
- 1,408
- 30
- 91
to reset it, you'd have to un/recheck what ever you changed.  failing that, you'd have to remove the users you added and re-add them.  But only do that to users/groups you created not any default account.
Did it tell you which file or directory you got the error for? were you trying to copy some system files/folder?
In windows 7, i'd have to check a windows 10 box, the default accounts listed in a base install for file security are Authenticated users, System, Administrators, and Users. If you opt to remove a whole account, make sure you don't mess with these.
