- Dec 18, 2003
- 3,628
- 1
- 0
Hi. I am a long time overclocker but I am perplexed by this problem. I've been water cooling my CPU's since my 2500+ Barton, so I have quite a bit of experience.
My setup:
G0 Q6600 @ stock (crappy 1.3v VID)
2x2gb 1000mhz
Gigabyte GA-X38-DS4
2x HD3870
Watercooling setup:
DangerDen TDX on the Q6600
2xEK full cover water blocked on the 3870's
3x120mm Black Ice Xtreme radiator
Eheim 1250 water pump.
My problem: TEMPS. The temps on the 3870's are great; 38C Idle, 45C load. The Q6600, on the other hand, is not so good. Idles at around 38-40C and load hits 65C. This is unacceptable at stock speeds. I've reseated the block about 3 times and made sure it's extra tight. I've gotten the chip up to 3.0ghz but it is not stable and hits ~72C.
I'm about to throw in the towel and buy a nice air cooler and only WC the two GPU's. Any ideas? I can post more info if needed.
My setup:
2x2gb 1000mhz
Gigabyte GA-X38-DS4
2x HD3870
Watercooling setup:
